Vista pc with serial Boe board & BS2PX
I tried to connect my serial boe board with a BS2PX on it to my desktop computer(it has a built in com port) which has Windows Vista SP1 installed and when I try to download a basic stamp program from Peditor is says that it didnt find a basic stamp. I tried the exact same configuration on a laptop with Windows XP SP3 and a USB-to-Serial adapter and guess what....it works just fine! Now where is the problem on the desktop pc?
Dave
Dave Andreae
Parallax Tech Support·
Jeff T.
You would want to install the Vista drivers that are made for the USB to Serial Adapter that you are using. Can you verify that the module is installed correctly by reviewing the following: Device Manager => Ports (COM & LPT) => USB to Serial device. Do you see any yellow exclamation (!) next to·the device; if so·this would indicate that the proper driver has not been installed.
Also, which version of the BASIC Stamp Editor do you have installed?
Respectfully,
Joshua Donelson
www.parallax.com
