Two intervals from one pulse train — Parallax Forums
Jim BarnesJim Barnes Posts: 9
edited 2009-03-19 16:50 in Propeller 1
Hi Gang,
Need to measure two time intervals from one signal.··First is the time high of a ~ 1-5 ms positive going pulse.· Secons is the period, or time·from the same initial high edge to the next high edge.· Ideally this is a 10:1 ratio, and ultimately the ratio is what I'm after, so a duty cycle measurement might suffice (?)
My pseudo-code:
VAR long ratio, long t1, long t2, long counter
·t1 = t2 = ratio = 0
wait for high edge
····· start counter··································· OR······· start ctrA, ctrB ·on highedge
····· wait for low edge·········································
············ t1 = counter·· 'short time······················ Stop ctrA on low edge,·· t1 = ctrA
····· wait for next high edge·································Stop ctrB on·high edge,·· t2 = ctrB
·············t2 = counter·· 'long time
······ratio = t2/t1
OR·
Start ctrA
The waitpeq looks promising but I thought the built in counter functions may be a better choice but alas, I am slightly confused with their structure.··I need counter resolution of at least 1 us· or better, and preferably the two times are measured from the same starting edge.·
Any help is appreciated.· Thanks,
Jim
  • virtuPICvirtuPIC Posts: 193
    edited 2009-03-19 06:36
    You don't even need any cog counter. The system counter is sufficient:
    waitForHighEdge()
    toHigh1st := cnt
    waitForLowEdge()
    toLow := cnt
    waitForHighEdge()
    toHighEdge2nd()
    highDuration := toLow - toHigh1st
    periodDuration := toHigh2nd - toHigh1st
    ratio := highDuration / periodDuration
    You can implement wait...() function with wait... instructions in SPIN or PASM. If they need have the same execution / delay times (do they?) you won't introduce any error by using this software instead of hardware.
    Airspace V - international hangar flying!
    www.airspace-v.com/ggadgets for tools & toys
  • Jim BarnesJim Barnes Posts: 9
    edited 2009-03-19 16:27
    Thanks v-P,
    I'm trying to figure this language out and not be totally helpless.· The way I understand what you wrote is that I use the waitpeq() as follows for a pulse on, say, ·pin3:
    waitpeq(%0000,· %1000, 0)······ '· wait for low on pin3 before starting--the mask is always %1000 to isolate pin3
    waitpeq(%1000, %1000, 0)······· '· wait until first high transition of pin3
    toHigh1st := cnt······················· ' initial count
    waitpeq(%0000, %1000,0)········ ' wait for pulse to come back to low
    toLow := cnt····························· ' count acquired as of end of pulse
    waitpeq(%1000, %1000,0)········ ' wait for next high transition
    tohigh2nd := cnt······················· ' count acquired as of next high
    '· now post processing
    Thanks for your time and please point out any errors in my way of thinking!!
    Jim
  • AribaAriba Posts: 2,697
    Try this concrete code (in opposite to pseudo code) :
    PUB GetRatio(pin) : ratio | t1,t2,pmsk
      pmsk := |< pin
      waitpne(pmsk,pmsk,0)     'wait until low
      waitpeq(pmsk,pmsk,0)     'wait until high (pos edge)
      t1 := cnt
      waitpne(pmsk,pmsk,0)     'wait until low (neg edge)
      t2 := cnt-t1
      t1 := cnt-t1
      ratio = t2*1000/t1       'ratio in permille (1/1000)
    I have it not tested, this is your turn...
    Andy
    Edit: Sorry, missed your last post, looks very similar [noparse]:)[/noparse]
    Post Edited (Ariba) : 3/19/2009 5:01:03 PM GMT
