The best range ( RF power )
I need to turn on and off a motor with two Basic Stamps.
One Basic Stamp at the transmitter and the other one at the receiver.
But my problem is that I need 15 miles ( very long range)
Do you know where can I buy long range transmitters?
Thanks, Mark
Thanks, Mark
- Stephen
Note that the 40 miles is for line of sight, with 3000 ft being the range in urban situations.
This link may help too: http://forums.parallax.com/showthread.php?p=759557
sight and any object at center distance. With those transmitters you can legally use a 6dbi antenna at max power. But for long distance I would reduce the power level and increase the gain of the antenna to 15dbi. This will result in the same effective power with less interference. Anyway this is about the only solution with out the need of a Licence. If you do have clear line of sight you can also opt for 2.4 gig or 5 gig equipment. You should be able to find 2.4 gig equipment cheaper then the 900mhz. 900 mhz just penetrates trees better.
The best solution I found at digi.com is the Xtend module.
But there are buildings between the signal (between the antennas).
So, I need more power.
I know it is almost impossible to find a product but If you know about any other alternative
will be very useful .
thanks, Mark
manzana , AB4OB , ham 47 years
KD8CUN Pat
