What's the fastest way to...
CannibalRobotics
What's the fastest way to set the Z or C flag in assembly? I'm using the following to toggle a clock line but it's taking too long when you couple it with the cycle overhead of the CALL statement.
It's imbedded in a driver for an ADC088S052. The usage is this:
All these clock calls are driving up the time but I can't seem to figure out a way to directly toggle the port without doing a flag related operation.
Any ideas?
Jim-
Signature space for rent!
Send $1 to CannibalRobotics.com.
CL_ON MOV s,#0 '
TEST s,#0 wz ' Sets Z flag to 1
muxz dirA,CL_Mask ' Set CL to 1
muxz OUTA,CL_Mask ' Set CL to 1
CL_ON_Ret ret
CL_Off MOV s,#0 '
muxz dirA,CL_Mask ' Set CL to output
muxnz OUTA,CL_Mask ' Set CL to 0
CL_Off_Ret ret
CALL #CS_Off ' Chip Select Low, wake up ADC
CALL #CL_Off ' 3 clock pulses to initiate conversion
CALL #CL_On '
CALL #CL_Off '
CALL #CL_On '
CALL #CL_Off '
SHR t2,#2 ' Shift it right 2 places (MSB out first)
AND t2,#%0_0000_0001 wz wc ' Test LSB
muxz OUTA,DI_mask ' Put a 1 on data line
muxnz OUTA,DI_mask ' Pot a 0 on data line
CALL #CL_On ' Clock High
MOV t2,ADChan ' Get ADChan again
SHR t2,#1 ' Shift it right once for middle bit
Any ideas?
Jim-
Use:
or outa, CL_Mask
to set the output high. Use:
andn outa, CL_Mask
to set it low.
Neither of these will upset other bits in outa.
No calls required.
ANDN outa, bitmask to clear port bit
bitmask long |< pin 'creates a long that has a single bit high that corresponds to the pin
Parallax Forums - If you're ready to learn, we're ready to help.
