Can I have 2 RC Sumobots if I just buy two of the Wireless Robotics Kits? — Parallax Forums
tpyo72682tpyo72682 Posts: 5
edited 2009-03-22 07:40 in Robotics
Hello,
I have bought 2 Wireless Control for Robotics kits and have successfully installed them in two Sumobots.
For the transmitter: I have connected joysticks to the Homework boards and set them up with the Rf transmitter.
For the receiver:· I have plugged in the Rf receiver to the Sumobot breadboard.
I have remote control sumobots and they work perfectly, when only one is turned on.
But what do I do when I want to control two sumobots, each with a separate joystick?· I noticed that when two transmitters are on, the robot sometimes acts jittery and motions (like going forward) are jerky and not smooth.
I don't know much about frequencies- is what I'm trying to do even possible with the hardware I've got?
  • N-2-STUFFN-2-STUFF Posts: 25
    edited 2009-03-17 05:00
    sounds like they are on the same chanel
  • SRLMSRLM Posts: 5,045
    edited 2009-03-17 05:02
    You'll have to do some code modification, and you may have to get another receiver. Here's what I'm thinking:
    Each transmitter can transmit at once, leading to interference.
    Therefore, you have to have each transmitter 'take turns' transmitting their data.
    A way to do this is to have one transmitter module be a 'master' and the other a 'slave'. The slave waits for breaks in the transmission of the master.
    The receiver can pick up each transmitted signal.
    To distinguish between one transmitter and another, each transmitter needs to include a unique header in the transmitted data(like 'a' or 'b')
    The easiest solution to determine breaks would be to get another receiver, but you could also connect the transmitters via wire or some other form of communication (like IR).
  • tpyo72682tpyo72682 Posts: 5
    edited 2009-03-17 18:19
    This is my code for transmitter A:
    SEROUT 8, 16468, [noparse][[/noparse] "!", x.HIGHBYTE, x.LOWBYTE, y.HIGHBYTE, y.LOWBYTE ]
    This is my code for transmitter B:
    SEROUT 8, 16468, [noparse][[/noparse] "@", x.HIGHBYTE, x.LOWBYTE, y.HIGHBYTE, y.LOWBYTE ]
    This is my code for receiver A:
    SERIN 2, 16468, [noparse][[/noparse]WAIT("!"), x.HIGHBYTE, x.LOWBYTE, y.HIGHBYTE, y.LOWBYTE]
    This is my code for receiver B:
    SERIN 2, 16468, [noparse][[/noparse]WAIT("@"), x.HIGHBYTE, x.LOWBYTE, y.HIGHBYTE, y.LOWBYTE]
    What does changing the baudmode do?
    Are all parallax receivers and transmitters set to the same channel?
    Can I change the channel myself?
    edited 2009-03-18 05:09
    For baudmode, there is an exhaustive discussion under the SEROUT/SERIN commands in the Basic Stamp Syntax and Reference Manual.
    Yes, the parallax devices transmit on the same frequency that you can't change (without lot's of radio electronics knowledge at least and the high risk of ruining the modules).
  • roadrunner3groadrunner3g Posts: 36
    edited 2009-03-20 03:55
    you can only use one transmitter at a time. ie... Txa on and Txb on = bad signal, a or b on = good signal.
    an idea to try would be connect both controller's to one transmitter and have the two receiver's decode the data. ie... a-0010+ b-0001= 00100001 (Tx), Rxa 0010xxxx and Rxb xxxx0001. there are other ways to do it also. serout has 8data bits = 256 combos/ 2 bots.
  • JDJD Posts: 570
    edited 2009-03-20 16:00
    tpyo72682
    A way we have addressed this in some of our shows is to have one SumoBot being controlled with the 433 MHz and the other controlled via IR Remote. However, you could try using a WAIT modifier in the SERIN, to help distinguish one Robot from the other.
    A common demo we have at shows is to have·two SumoBots in the ring with·433 MHz controls; which people can walk up and control them to have a battle right there. It's a great eye catcher, and really fun to play with.
    WAIT·Modifier Example:
    Robot A
    SERIN, PIN, BAUD, [noparse][[/noparse]WAIT("!A"), Movement Commands]
    Robot B
    SERIN, PIN, BAUD, [noparse][[/noparse]WAIT("!B"), Movement Commands]
    I hope this helps,
    Respectfully,
    Joshua Donelson
    www.parallax.com
    Thank you so much for you replies!· I got it working.·· I had to attach both of the joystick controls to one transmitter,·and I used the WAIT modifier, like Joshua suggested.
    Before I read this reply I went to Radio Shack and bought a $15 RC car, so could use it's guts.· I·made some progress but·I abandoned it when I read your suggestions and realized how easy it was.
    I'm a teacher for our high school's freshmen engineering class and I thought this would be a fun project.· I'm supplying the control system and servos, and they're designing the chasis and drive train.· After·they finish designing it on paper and CAD, they'll construct it and we'll have a robotics triathalon.· Events will be Sumo, Soccer, and I haven't decided the last event.· Maybe an obstacle course?· Any suggestions?
    I made the joysticks from some arcade joysticks I bought from happcontrols when I·played a lot of fighting games.· I attached a picture of them at the bottom of this post.· I bought some plastic tupperware from Target and drilled some holes in them, and bam- instant high school robot olympics.
    Here's the code I used.· It's very sloppy, but it gets the job done, and now I can move on with my life.· It's a direct rip off of the parallax wireless robotics code and the sumobot competition code.· I hope this helps someone!
    ' TransmitArcadeDriveAB.bs2
    '{$STAMP BS2}
    '{$PBASIC 2.5}
    'Parallax 433.92 MHz RF Receiver (#27981) Sample Tx Code (BS2)
    'Connect Pin 8 of the BS2 to the DATA line on the RF module
    'Connect +5v to the 5v line, connect Ground to the GND line
    'This code will transmit two word sized counters, byte at a time.
    'Note the PULSOUT instruction: this helps the receiver sync with
    'the transmitter, especially after lapses in communication
    'This code transmits at 9600 baud, inverted.
    a VAR Word
    b VAR Word
    x VAR Word
    y VAR Word
    DO
    x = 0
    y = 0
    a = 0
    b = 0
    '1 = forward
    '2 = right oblique
    '3 = right spin
    '4 = right back oblique
    '5 = backward
    '6 = left back oblique
    '7 = left spin
    '8 = left oblique
    'Sumobot A
    IF (IN0 = 1) THEN
    a = 1
    ENDIF
    IF (IN1 = 1) THEN
    a = 3
    ENDIF
    IF (IN2 = 1) THEN
    a = 5
    ENDIF
    IF (IN3 = 1) THEN
    a = 7
    ENDIF
    IF (IN0 = 1 AND IN1 = 1) THEN
    a = 2
    ENDIF
    IF (IN1 = 1 AND IN2 = 1) THEN
    a = 4
    ENDIF
    IF (IN2 = 1 AND IN3 = 1) THEN
    a = 6
    ENDIF
    IF (IN3 = 1 AND IN0 = 1) THEN
    a = 8
    ENDIF
    'Sumobot B
    IF (IN4 = 1) THEN
    b = 1
    ENDIF
    IF (IN5 = 1) THEN
    b = 3
    ENDIF
    IF (IN6 = 1) THEN
    b = 5
    ENDIF
    IF (IN7 = 1) THEN
    b = 7
    ENDIF
    IF (IN4 = 1 AND IN5 = 1) THEN
    b = 2
    ENDIF
    IF (IN5 = 1 AND IN6 = 1) THEN
    b = 4
    ENDIF
    IF (IN6 = 1 AND IN7 = 1) THEN
    b = 6
    ENDIF
    IF (IN7 = 1 AND IN4 = 1) THEN
    b = 8
    ENDIF
    PULSOUT 8, 1200 'Sync pulse for the receiver
    SEROUT 8, 16468, [noparse][[/noparse] "!B", b.HIGHBYTE, b.LOWBYTE, y.HIGHBYTE, y.LOWBYTE ]
    SEROUT 8, 16468, [noparse][[/noparse] "!A", a.HIGHBYTE, a.LOWBYTE, x.HIGHBYTE, x.LOWBYTE ]
    'HIGH 0
    PAUSE 10
    LOOP
    'ReceiveArcadeDriveA.bs2
    '{$STAMP BS2}
    '{$PBASIC 2.5}
    'Parallax 433.92 MHz RF Receiver (#27981) Sample Rx Code (BS2)
    'Connect I/O Pin 2 of the BS2 to the DATA line on the RF module
    'Connect +5v (Vdd) to the 5v line, connect Ground (Vss) to the GND line
    'This code will look for an "!", then read in four bytes.
    'The first two bytes will be the high and low bytes of a word variable (x),
    'the second two bytes will be the high and low bytes of a second word variable (y).
    'The values of x and y will be sent out TO the DEBUG terminal.
    'An optional LED (with proper current limiting resistor) may be connected to the
    'BS2 I/O pin 0, this will blink when data is received.
    'This code receives at 9600 baud, inverted.
    [noparse][[/noparse] I/O Definitions ]
    LMotor······ PIN······· 13····················· ' left servo motor
    RMotor······ PIN······· 12····················· ' right servo motor
    LfIrOut····· PIN······· 4······················ ' left IR LED output
    LfIrIn······ PIN······· 11····················· ' left IR sensor input
    RtIrOut····· PIN······· 15····················· ' right IR LED output
    RtIrIn······ PIN······· 14····················· ' right IR sensor input
    [noparse][[/noparse] Constants ]
    LFwdFast···· CON······· 1000··················· ' left motor fwd; fast
    LFwdSlow···· CON······· 775···················· ' left motor fwd; slow
    LStop······· CON······· 750···················· ' left motor stop
    LRevSlow···· CON······· 725···················· ' left motor rev; slow
    LRevFast···· CON······· 500···················· ' left motor rev; fast
    RFwdFast···· CON······· 500···················· ' right motor fwd; fast
    RFwdSlow···· CON······· 725···················· ' right motor fwd; slow
    RStop······· CON······· 750···················· ' right motor stop
    RRevSlow···· CON······· 775···················· ' right motor rev; slow
    RRevFast···· CON······· 1000··················· ' right motor rev; fast
    [noparse][[/noparse] Variables ]
    irBits······ VAR······· Nib···················· ' storage for IR target data
    irLeft······ VAR······· irBits.BIT1
    irRight····· VAR······· irBits.BIT0
    lastIr······ VAR······· Nib···················· ' info from last reading
    pulses······ VAR······· Byte··················· ' counter for motor control
    [noparse][[/noparse] Initialization ]
    Reset:
    · LOW LMotor··································· ' initialize motor outputs
    · LOW RMotor
    [noparse][[/noparse] Program Code ]
    '1 = forward
    '2 = right oblique
    '3 = right spin
    '5 = backward
    '7 = left spin
    '8 = left oblique
    Main:
    a VAR Word
    x VAR Word
    DO
    LOW 0
    SERIN 2, 16468, [noparse][[/noparse]WAIT("!A"), a.HIGHBYTE, a.LOWBYTE, x.HIGHBYTE, x.LOWBYTE]
    HIGH 0
    PAUSE 10
    DEBUG ? a
    'DEBUG ? x
    IF( a = 1 ) THEN
    · PULSOUT RMotor, RFwdFast
    · PULSOUT LMotor, LFwdFast
    ENDIF
    IF( a = 2 ) THEN
    · PULSOUT RMotor, RFwdSlow
    ENDIF
    IF( a = 3 ) THEN
    · PULSOUT RMotor, RRevSlow
    · PULSOUT LMotor, LFwdSlow
    ENDIF
    IF( a = 4 ) THEN
    · PULSOUT LMotor, LRevFast
    ENDIF
    IF( a = 5 ) THEN
    · PULSOUT RMotor, RRevFast
    ENDIF
    IF( a = 6 ) THEN
    · PULSOUT LMotor, LRevSlow
    ENDIF
    IF( a = 7 ) THEN
    ENDIF
    IF( a = 8 ) THEN
    ENDIF
    LOOP
    'ReceiveArcadeDriveB.bs2
    '{$STAMP BS2}
    '{$PBASIC 2.5}
    Reset:
    · LOW RMotor
    '1 = forward
    '2 = right oblique
    '3 = right spin
    '5 = backward
    '7 = left spin
    '8 = left oblique
    Main:
    b VAR Word
    y VAR Word
    DO
    LOW 0
    SERIN 2, 16468, [noparse][[/noparse]WAIT("!B"), b.HIGHBYTE, b.LOWBYTE, y.HIGHBYTE, y.LOWBYTE]
    HIGH 0
    PAUSE 10
    DEBUG ? b
    'DEBUG ? y
    IF( b = 1 ) THEN
    ENDIF
    IF( b = 2 ) THEN
    ENDIF
    IF( b = 3 ) THEN
    ENDIF
    IF( b = 4 ) THEN
    ENDIF
    IF( b = 5 ) THEN
    ENDIF
    IF( b = 6 ) THEN
    ENDIF
    IF( b = 7 ) THEN
    ENDIF
    IF( b = 8 ) THEN
    ENDIF
    LOOP
    816 x 612 - 47K
