i use DS1302 timer and want to make a calculation
We read the datetime value from DS1302 it work fine
GOSUB ReadRTCBurst
DEBUG 2,1,1,"jaar=", HEX2 Year," maand=", HEX2 Month," dag=",HEX2 Date," uur=", HEX2 Hours," min=", HEX2 Minutes," sec=",HEX2 Seconde
Now we want to make a calculation with the datetime variables
······· IF·Minutes=15 THEN
········· temp = ((Month * 1736) - 1736) + ((Date * 56) - 56) + (((Hours-6) * 4) - 4) + 1
······· ENDIF
······· IF Minutes=30 THEN
········· temp = ((Month * 1736) - 1736) + ((Date * 56) - 56) + (((Hours-6) * 4) - 4) + 2
······· ENDIF
······· IF Minutes=45 THEN
········· temp = ((Month * 1736) - 1736) + ((Date * 56) - 56) + (((Hours-6) * 4) - 4) + 3
······· ENDIF
······· IF Minutes=60 THEN
········· temp = ((Month * 1736) - 1736) + ((Date * 56) - 56) + (((Hours-6) * 4) - 4) + 4
······· ENDIF
······· IF (Minutes=15) OR (Minutes=30) OR (Minutes=45) OR (Minutes=60) THEN
········· HIGH 11:SEROUT 10\11,16780,[noparse][[/noparse]"TIM ",DEC temp]
······· ENDIF
The issue is that if Minutes=15 then minutes=special character
I can debug Minutes with HEX and the value is ok.
How can i change it to a decimal number
Seconde VAR· Byte
Minutes VAR· Byte
Hours· VAR· Byte
Date· VAR· Byte
Month· VAR· Byte
Day· VAR· Byte
Year· VAR· Byte
'==================== DS1302 Real-Time Clock Subroutines ===================
PrintIt:
· 'Prints zero (0) terminated text from EEPROM
· READ Idx,Value··· 'Get next character
· IF Value = 0 THEN Finished· 'Make sure it's not a binary 0
· DEBUG Value····· 'Display it on screen
· Idx = Idx + 1
· GOTO PrintIt
Finished:
RETURN
WriteRTCRAM:
·'Write to DS1302 RAM Register
· HIGH RTCCS
· SHIFTOUT Dta, Clk, LSBFIRST, [noparse][[/noparse]%0\1,RTCCmd\5,%11\2,Value]
· LOW RTCCS
RETURN
WriteRTC:
·'Write to DS1302
· HIGH RTCCS
· SHIFTOUT Dta, Clk, LSBFIRST, [noparse][[/noparse]%0\1,RTCCmd\5,%10\2,Value]
· LOW RTCCS
RETURN
ReadRTCBurst:
·'Read all time-keeping registers in one burst
· HIGH RTCCS
· SHIFTOUT DTA, Clk, LSBFIRST, [noparse][[/noparse]%1\1,BrstReg\5,%10\2]
· SHIFTIN DTA, Clk, LSBPRE, [noparse][[/noparse]Seconde,Minutes,Hours,Date,Month,Day,Year]
· LOW RTCCS
RETURN
ReadRTCRAM:
·'Read DS1302 RAM Register
· HIGH RTCCS
· SHIFTOUT DTA, Clk, LSBFIRST, [noparse][[/noparse]%1\1,RTCCmd\5,%11\2]
· SHIFTIN DTA, Clk, LSBPRE, [noparse][[/noparse]Value]
· LOW RTCCS
RETURN
SetTimeAndDate:
· 'Write time values into all time-keeping registers, being sure to clear
· 'the write-protect bit in CtrlReg before the write, and set the
· 'write-protect bit after the write
· FOR Idx = 0 TO 8
··· LOOKUP Idx,[noparse][[/noparse]0,$00,Minutes,Hours,Date,Month,Day,Year,128],Value
··· LOOKUP Idx,[noparse][[/noparse]CtrlReg, SecReg, MinReg, HrsReg, DateReg, MonReg, DayReg, YrReg, CtrlReg],RTCCmd
··· GOSUB WriteRTC
· NEXT
RETURN
GOSUB ReadRTCBurst
······· ENDIF
······· ENDIF
······· ENDIF
······· ENDIF
······· ENDIF
Seconde VAR· Byte
Minutes VAR· Byte
Hours· VAR· Byte
Date· VAR· Byte
Month· VAR· Byte
Day· VAR· Byte
Year· VAR· Byte
PrintIt:
· Idx = Idx + 1
· GOTO PrintIt
Finished:
RETURN
WriteRTCRAM:
· HIGH RTCCS
· LOW RTCCS
RETURN
WriteRTC:
·'Write to DS1302
· HIGH RTCCS
· LOW RTCCS
RETURN
ReadRTCBurst:
· HIGH RTCCS
· LOW RTCCS
RETURN
ReadRTCRAM:
· HIGH RTCCS
· LOW RTCCS
RETURN
SetTimeAndDate:
· FOR Idx = 0 TO 8
··· GOSUB WriteRTC
· NEXT
RETURN
hours = hours.nib1 * 10 + minutes.nib0
and so on, converts BCD to decimal.
Watch out for a negative result in (hours-6)
Tracy Allen
www.emesystems.com
