USB using FullDuplex stops with VB
When my Propeller program is launched the USB port sends and receives data fine from a VB application I created. If however I stop the VB application and then start the VB application up again the USB· port will not respond. The same thing happens with HyperTerminal. I must restart the Propeller application.
There does not seem to be a problem if the Propeller program is running for a while then I launch either VB or HyperTerminal only if shut down then restarted.
In my VB application I tried shutting down the comm port·before program shutdown but that had no effect.
Any way to keep the USB port functional when the terminal application may have to be restarted?
-tellurian
