ICCV7 Assemby File problems
I decided to delve into PASM but with ICCV7. I can create assembler source files and compile OK (still at the blinky LED stage) but when I try to add some data no matter what I do the compiler rejects it as an invalid mnemonic. Note that the syntax is slightly different between the Prop Tool and ICCV7.
for example: (the blinky LED)
If I try to add some data (clock delay value in this case) using:
It always fails with and "illegal mnemonic specified" error.
I can't find any code examples for ICCV7 and the documentation is, well, poor (non existent with regard to ASM).
This is a silly thing to get stuck on (I feel foolish) but I am stuck. Hopefully someone can send me some samples or info.
thanks,
-tellurian (Allen)
.area cog(abs) _blink:: rdlong USER1, par ; read in the pin to toggle mov USER0, #1 ; convert pin to bit mask shl USER0, USER1 or DIRA, USER0 ; set the pin to output mov USER1, #1 ; create wait delay shl USER1, #23 ; = 8388608 ~ 0.1048576 sec mov USER2, cnt ; setup wait count add USER2, USER1 lp: xor OUTA, USER0 ; xor pin state to toggle waitcnt USER2, USER1 ; wait delay time jmp #lp ; repeat
dat1: .long 8000000
dat1: long 8000000
thanks,
-tellurian (Allen)
There are other issues with the assembler that I've run into working on the kernel.s file ... the assembler program crashes (not the ide) with certain things there because of hardcoded addresses (not unreasonable for that file) ... I don't know how common it is with non-kernel.s files, but any program crash with no reason at some point should be fixed.
--Steve
Propalyzer: Propeller PC Logic Analyzer
http://forums.parallax.com/showthread.php?p=788230
I turn off tabs, but I guess I will have to turn them back on. I hoped that ICCV704C would solve my problem but after downloading it I cannot compile anything, even previous unchanged code that built fine with ICCV704B. Richard Man at Imagecraft will look into this when he gets back.
OK, I just tried it, it worked, thanks. I hope to get back to no tab characters soon though.
Your basic outline of ICCV7 "object" content looks good to me.
regards,
Allen
