Using onboard programming USB port for serial communication to PC
Hi
I know that the propeller is usually programmed using the USB/Serial via P30/P31. The manual states that these pins can be used for normal I/O after it starts.
However, I tried using the SimpleDebug module to send and receive, but it does not appear to work. Below is an extract from it, that gave me this idea:
PUB start(baud) : okay
'' Starts uart object (at baud specified) in a cog
'' -- uses Propeller programming connection
'' -- returns false if no cog available
· okay := uart.start(31, 30, 0, baud)
It suggests that I only need to set the baud rate, and can use the rest of the functions.
On the PC, I used HyperTerm matching the speed setting in my spin code, with a simple echo loop, sending back what the prop receives.·I can tell the USB is receiving my typed characters, as the onboard RX LED flashes as expected. However, the TX LED is continuously on, and the HyperTerm receives nothing.
What am I missing/doing wrong?
Thanks for the help,
Chris
Chris
Thanks for the reply.
As I said it's quite simple echo loop, code below:
Obj
Debug : "SimpleDebug"
Pub Main | ch
Debug.start(9600)
dira[noparse][[/noparse]0]~~ 'enable P0 for output to toggle LED on each char received
repeat
ch := Debug.getc
!outa[noparse][[/noparse]0]
Debug.putc(ch)
I thought it might be HyperTerm signalling DTR, which in turn resets the prop chip. I tried turning off hardware flow on HyperTerm.
Chris
I made some progress. The DTR is causing the prop to be reset, and I was testing to RAM, so the previous EEPROM code was running!
The loop is working, but getting garbage chars back, which indicates speed mismatches. Will try to slow down the speed.
_Chris
However, also setting HyperTerm to 7 bits worked without doing that, but I except 300 baud to be slow enough for it to work.
Thanks for your help,
_Chris
