BS2 on a breadboard
I have 2 BS2's but only 1 BOE and I want to do some serin/serout experiments. I just need to know what the minimum connections are for using the BS2 from a breadboard. I have a regulated 5V supply.
...also, do I need any resistors between the 2 Stamps or can I interface them directly?
Post Edited (Aidanx1) : 3/15/2009 4:19:22 PM GMT
However, the BoE does have a connector for a standard serial cable which makes it easy to re-program the Stamp, this is a bit of a pain to do on a regular breadboard. You'd have to hack off the end of a cable to get to the wires, or come up with some type of adapter.
Resistors on the IO pins is always a good idea while experimenting, 220 - 1k ohms or so.
- Rick
On an integrated circuit like the Propeller, if you only connect some of the grounds, you can damage the chip under some circumstances.
