Line follower with Photoresistors
I would like to show you my line follower with Photoresistors. (It's my DIY construction so I don't know is it a good topic there
Only what you need to build this sensor are 3 photoresistors (e.g VT935G-B).
The ciruit is simple:
My program is using RCTIME Command and copare time from 3 circiut .
There is a short video:
www.youtube.com/watch?v=sKapEdJaOzg
Of course It's only prototype, but I think this sensor can be use in diffrent project with boe-bot
time1 VAR Word
time2 VAR Word
time3 VAR Word
DO
'first photoresistor
HIGH 15
PAUSE 3
RCTIME 15,1, time1
'second photoresistor
HIGH 6
PAUSE 3
RCTIME 6,1, time2
'third photoresistor
HIGH 0
PAUSE 3
RCTIME 0,1, time3
DEBUG HOME,"time1= ", DEC5 time1 , "time2= ", DEC5 time2,"time3= ", DEC5 time3
IF (time1 > time2 ) AND ( time1> time3 ) THEN
PULSOUT 13, 650 ' Left rotate
PULSOUT 12, 650
HIGH 14
ENDIF
IF ( time3 > time2 ) AND ( time3 > time1) THEN
PULSOUT 13, 850 ' Right rotate
PULSOUT 12, 850
HIGH 1
ENDIF
IF (time2 > time1) AND ( time2> time3 ) THEN
PULSOUT 13, 850 ' Forward
PULSOUT 12, 650
HIGH 7
ENDIF
LOOP
humanoido
There is the same sensor but soldered to copper wire:
In this design, photoresistors have a common mass, so you don't have to conect photoresistor to Vss
(under the robot you can see additional wire, but it's a part from diffrent projekt )
