Boe-Bot Griper kit HELP!
Hi, i just recently installed a gripper kit for my boe-bot and am having some trouble programming it. I need to know how to make it move whilst gripping the object. Please help me with how to write a program to allow this.
Need to know ASAP (urgently!)
Just a question though, is it possible for the boe-bot to use sensors to track an object and then pick it up with
the gripper??
I would like to ask you how you do your programming for the gripper.
James
What I am planning to do is use a line following module which has the ability to detect a main line and a line intersection. The main line will lead the robot to the object, and a line perpendicular to the main line indicates the object is dead ahead. The robot will then grab the object, turn around, and follow the line to the drop point which is also indicated by another line perpendicular to the main line.
I think the CMU cam can be used as well, but that's more than I want to spend right now.
