Propeller - 40 pin - pin label — Parallax Forums
MikeSMikeS Posts: 131
edited 2009-03-14 03:51 in Propeller 1
Does anyone know how to obtain/make the "pin-out" label that comes with the PE-Kit for the 40 pin Propeller. I could not find them on the Parallax site and I have not had any luck printing them at the exact size of the chip.
MikeS
Post Edited (MikeS) : 3/13/2009 5:04:49 PM GMT
120 x 277 - 9K
  • SRLMSRLM Posts: 5,045
    edited 2009-03-13 16:46
    I put this as a suggestion on the new products from Parallax thread, but I think it got buried... You could always take the image and print it onto a name badge. It's certainly not as nice, but with some trimming it could work.
  • CannibalRoboticsCannibalRobotics Posts: 535
    edited 2009-03-13 17:14
    I took the image you posted and printed it at a 65% reduction and it came out pretty close. You could probably get it closer and print it on an adhesive backing like a 3 x 1 mailing label. An Exacto would finish the job.
    This is a photo of the 65% printout sitting next to another 40 pin DIP. The detail of the iPhone camera is lacking but I can read everything quite well.
    Are you looking for this to do breadboard work or from the underside reversed for wire wrap? (Does anyone do that anymore?)
    Jim-
    When your problem seems insurmountable, read the forum for a while.
    Solve someone else's problems and yours won't seem so bad.
    1200 x 1600 - 280K
    edited 2009-03-13 18:32
    I wire rap some times but not often
    Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
  • MikeSMikeS Posts: 131
    edited 2009-03-13 19:39
    CannibalRobot,
    Yea, I can print it very close with MSWord but there is a little creeping of the Pin number spacing. It just makes breadboarding a lot easier. I use to wire wrap, but not in a long time.
    MikeS
    edited 2009-03-13 20:02
    I still have a goodly wad of these labels left over from the PropStick Kit. They're made of polyester. If you send me an email (see my profile), I'll reply with an address to send a SASE for five of them. (U.S. addresses only, please.) First-come-first-served until they're gone.
  • WhitWhit Posts: 4,194
    edited 2009-03-13 20:32
    You can also see this thread - http://forums.parallax.com/showthread.php?p=729096 and order one of the old PropStick Kits (which come with the label).
    @ Phil -·I always wanted one so I just ordered a pair.
    Sorry to ask here, but can the Serial PropStick be modified for a PropPlug connection?
    Whit+
    edited 2009-03-13 20:41
    Whit,
    Thanks. It's been awhile since I've gotten one of those orders! I'll get it in the mail today.
    edited 2009-03-14 02:41
    Phil,
    Thanks for the offer, I'll PM you.
    MikeS
  • RizThomasRizThomas Posts: 24
    Of course, the best way is to get it from Parallax. However, if you have access to Corel Draw, I used the above "prop-label.jpg" and rezised them. After a few tries, iwas able to make the right size (aligned with each of the pins on both side). AFter that, I duplicated them to fill up 1 sheet of Laser Label (shiny).
    It was nice that these labels are "black and white"...I ketopt my origianl one that came with my PE-kit
