GPO
Anyone know of a relatively inexpensive solid state relay I could use with a GPO output for a 1 off device? High current not needed but would like to be able to handle any voltage input from 0-24VDC and 80-130VAC
Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
Most SSR's have input control voltages in the 3-24VDC range, although you could use an AC control signal by adding a rectifier/capacitor/resistor circuit on the input.
If the current is 100mA or less you could use one of the MOC 3020/3030 series. They are under a dollar each.
