BRIGHT BRIGHT leds, where to get them?
I'm looking for a supply of of super super bright LEDS. I found THIS and THIS on ebay. The one is twice as expensive as the other, but it's also got a metal heat sink. Does that mean it's going to be brighter? How do I know the brightness of leds when I'm buying them?
Also, do I just need a transistor and resistors to connect a couple of these up to the stamp?
Seperate from that, there are 5mm ultra-bright (the brightest) and super-bright (less bright)·LEDs that run off of 20 mA and stay cool for higher efficiency. These use 1.7-2.4 volts depending on the color. Non-diffused clear epoxy cases with a flat front are extremely bright over a wide viewing angle.
http://www.ledsupply.com/
