Overmolding Propeller Products
Not sure if this is necessarily the right place to post this, so I may post it in the Sandbox as well, but here goes...
Anybody overmolded a Propeller based product, what casting material did you use, and what were the results?
I'd like to take some things I'm working on, and mold them in a 'block' of material, such as liquid urethane plastic or epoxy.· Additionally, I'd like to do the same for some sensors (such as DS18B20, DS1620, etc).
I'm currently considering something like Smooth Cast 310 from Smooth-On Liquid Plastics & Rubber (www.smooth-on.com), but am concerned about dramtically altering the electrical properties as well as affecting the accuracy of temperature sensors.·
This is for an agricultural application, so the sensors will certainly see quite a bit of abuse, I can't think of a much better way to protect them.· It will also greatly reduce the complexity of producing sensors.
Any thoughts or insight would be greatly appreciated...
Scott
Scott
Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
· Home of the MultiBladeProps: TriBladeProp, SixBladeProp, website (Multiple propeller pcbs)
· Emulators (Micros eg Altair, and Terminals eg VT100) - index
· Search the Propeller forums (via Google)
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
You want to watch out for any "potting compound" or "epoxy" and make sure that it does not contain acetic acid .... A quick test, if it smells like vinegar, it's the wrong stuff.
To re-iterate what Timothy said, heat can be intense. If you have a way to control the catalyst (promoter) the better. A slower reaction will also reduce the amount of "yellowing" from the epoxy and eliminate air-bubbles if you want to be able to see what's inside. Timothy's point on conductivity is also important to consider, another is simply the dielectric property of the epoxy. In most applications this won't be an issue, but other designs might be sensitive to any dielectric changes that can alter the parasitic capacitance significantly.
Beau Schwabe
IC Layout Engineer
The material was about US$30 a litre, but the mould die was fairly expensive.
The unresolved concern I had with it was how it would stand up to UV sunlight over time
tubular
After about a month in the field these machines all started erasing all disks as the write line shorted to 5vdc. It took us months to figure out what was going on.
Jim-
When your problem seems insurmountable, read the forum for a while.
Solve someone else's problems and yours won't seem so bad.
Another material I've experimented with for coating in medium layers is E6000 from Eclectic Products. They suggest that it is suitable for electronic applications, but I have not seen much solid data to back up that claim. It does have desirable properties, one of which is to stick to almost anything, including low surface energy plastics like polyethylene.
Tracy Allen
www.emesystems.com
Tracy Allen
www.emesystems.com
