prop as XTAL
I know there has been talk about it before. But it is difficult to find things with the forum search engine.
I'm wondering what is need to run a Prop's xtal from another Prop. I'm not sure what the XTAL I/O pins are actually doing. I'm hoping it is as easy as wiring up a couple resistors between prop A output to prop B's xtals. Any cautions for running more than a couple Props off a single output?
For searching, use the link on my signature.
· Home of the MultiBladeProps: TriBladeProp, SixBladeProp, website (Multiple propeller pcbs)
· Emulators (Micros eg Altair, and Terminals eg VT100) - index
· Search the Propeller forums (via Google)
Any more tips would be helpful.
If I were doing this, I would probably loop the clock line through the various XTIs, rather than using a branching topology, and put pads for a termination network near the end of the loop. Here is a paper that discusses clock line termination.
Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
The wavelength (in a vacuum) of an 80 MHz clock is 3.75 meters. So synchronicity on a small board should be less of a concern than reflections and overshoots. I have a feeling that the PLLs will add more phase uncertainty than the onboard propagation time does, but I could be wrong about that.
