Extreme cold operations
I am designing a new long duration high altitude payload that will be powered by the Prop.· All the components MUST be rated for -40C (40F), -55C (-67F) where I can get them.
So far I have been able to find all components within my temperature range except one.· I am having a problem finding a 5MHz 20pF crystal rated for that low of a temperature.· I have found a 5MHz 18pF crystal rated at -40C in a metal can SMD (Mouser:695-HCM49-5-U) but I do not know how critical the 20pF is for Prop.· Plus … I would like to stay away from the SMD devices for this payload if possible.
So it boils down to 2 questions:
WWW.HAPB.NET
"Don't ask yourself what the world needs - ask yourself what makes you come alive, and then go do it." - H.T.Whitman
- Does anyone know where I can get a·NON SMD 5MHz 20pF crystal rated·for an operating temperature of -40C?
- If I use the SMD I found rated @ 18pF will this have an impact on the Prop performance?
WWW.HAPB.NET
I don't understand however, why basically the same package can have two different operating temperature ranges. For example, the HCM49 is rated for -40 degrees in surface mount, but the same package in through hole, the HC49, is rated only to -20 degrees. AFAIK, the surface mount HCM49 is made by bending out the wire leads of the HC49 along a pad a the bottom, so they come out at the ends for attachment to SMT pads. Otherwise the same crystal, same can. Maybe it has to do with better control over the stresses of mounting. Huh?
Tracy Allen
www.emesystems.com
Using temperature controlled heaters is a good idea but since the crystal is the only component I am having a problem with I would prefer to stay away from that solution right now.
Failure due to under rated components is·a major concern.· For my normal payloads I do not worry about the rated temperatures since I know my housing will stay warm during the 4 hour mission and·I·record temperature, however, this is not a normal or amateur mission.· The prop will be controlling balloon float at altitude, along with other critical functions for a period of days.· The temperature at 110,000 is -55C so the payload will get cold soaked over time.
WWW.HAPB.NET
Post Edited (Earl Foster) : 3/11/2009 3:45:01 PM GMT
If you decide that SMD is okay, here's one that runs at 80MHz on 3.3V (precluding necessity for the PLL), and operates down to -55C. Here's another with the same specs.
BTW, is your concern about SMD due to a difference in tempco between package and PCB, or because of other factors?
Post Edited (Phil Pilgrim (PhiPi)) : 3/11/2009 4:25:18 PM GMT
http://www.citizen.co.jp/english/crystal/aspect/index.html
The spec sheets say that their crystals (in certain SMT packages) will stay within 50ppm of the calibration frequency over a range of -10 to +60 C, but the operating temperature range is -40 to +85, and storage from -55 to +125. When I first got a Propeller, I stuck it in an environmental chamber and had it operating down to -65 degrees C using the standard HC49 crystal. Another thing, I don't ever recall seeing a graph of crystal impedance versus temperature, in terms of Q factor that would need to be accounted for in the oscillation circuit. It may not be a factor.
Maybe there is some limitation due to the packaging. In a project for a deep ocean probe that used one of our data loggers, they insisted that we take out the resistance welded metal resonator package and use an epoxy package instead, due to the high pressures that would be encountered.
Earl, the 18pF vs 20pF shouldn't make a significant difference.
Tracy Allen
www.emesystems.com
WWW.HAPB.NET
Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
I honestly don't know whether the tempcos between crystals/oscillators and fiberglass PCB materials are different enough to be an issue, though. Maybe they're not.
WWW.HAPB.NET
Since this is a critical mission, it seems that pre-flight testing of the whole Propeller system with crystal and circuit board is in order. Even when individual components are cold rated, the whole is more than the sum of the parts. If you don't have an environmental chamber that can reach down to -40 or below, a cooler and dry ice can be a go-no go test chamber, albeit harsh and uncontrolled. For reasons of supply and cost the space program sometimes "uprates" commercial components for use way beyond their specified temperature/humidity/radiation ratings, but they have a strict regimen for testing and handling and packaging them. Harsh testing is a double edged sword, as it can exacerbate the micro-cracks etc. that lead to ultimate device failure.
I'm curious, at that 20 mile altitude, do you expect high temperatures also due to solar radiation?
Tracy Allen
www.emesystems.com
What if you put your crystal right next to your voltage regulator - maybe even solder the heat sync tab to the can of the crystal. Epoxy a thermistor to the crystal can and see what happens.
Jim-
Signature space for rent, only $1.
Send cash and signature to CannibalRobotics.
The payload will be covered with the same material that is used on satellites to reflect solar radiation. Since I have never done a long duration flight before I do not know how much additional heating, if any, is expected. I was given the temperature rating specifications that I must follow in order to comply with mission parameters.
Jim ... that is a possibility. Since I have never been involved in a long duration mission this is new territory for me.
WWW.HAPB.NET
Through hole, 20pf, and a frequency stability of +- 100 over the operating range.
Also this 6MHz crystal.
In brief: Also check radiation tolerance of the prop and associated components. Especially Flash memory, RAM, and CMOS circuits.
Airspace V - international hangar flying!
www.airspace-v.com/ggadgets for tools & toys
