Baffling pcFullDuplexSerial4FC problem
I've been using pcFullDuplexSerial4FC exclusively in all my projects requiring serial. I ran across a problem, but I can figure out if it is my code or a serial problem.
There's the code:
Simple enough, just a test to see if the XBee is sending serial to the Prop. The XBee is sending the data to the Prop at 115 kbps, but only about 18 bytes a second.
I verified that the send and receive XBee's are set up correctly by taking the receive module off the proto board and plugging directly to the computer's serial port, and every packet came in as it should:
But, when I ran the above code, and echoed the data that the Prop received, it had a lot if irregularities, but obviuosly some repeating characters:
If I was getting complete garbage, I wouldn't be suprised, since I mess up like than all the time, but this time some byes repeat and some don't.
Any suggestions?
There's the code:
pub receiveLoop | char
uarts.str(DEBUG_PORT, string("Entering XBee receive loop", 13))
repeat
uarts.tx(DEBUG_PORT, uarts.rx(XBEE_PORT))
7e 00 7d 31 90 00 7d 33 a2 00 40 4b 22 77 ff fe 01 48 65 6c 6c 6f a4 7e 00 7d 31 90 00 7d 33 a2 00 40 4b 22 77 ff fe 01 48 65 6c 6c 6f a4 7e 00 7d 31 90 00 7d 33 a2 00 40 4b 22 77 ff fe 01 48 65 6c 6c 6f a4 7e 00 7d 31 90 00 7d 33 a2 00 40 4b 22 77 ff fe 01 48 65 6c 6c 6f a4
7e 00 fc b8 c8 80 be 26 34 10 b0 94 d2 d7 fe 01 48 65 e4 a6 a7 96 7e 00 fc b8 c8 80 be 99 d1 80 90 29 a4 d7 fe 01 48 65 6c 34 af 96 7e 00 fe 98 c8 80 be 26 34 20 b8 94 f2 d7 fe 01 48 65 6c 76 bf 96
Any suggestions?
... no help at all, but it looks like the Prop just can't keep up. I almost never us 115 kbps as I find it can be flaky on many embedded platforms, especially if bit banging the serial ports.
tellurian
Yes, running at 80 MHz. I really need to keep if as fast as possible to reduce latency. Throughput is going to be small, but end to end byte times must be low as possible.
Come to think about, I've send data faster than this before with a hard-wired serial line, and didn't have any problem. Puzzling.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Mike G. could be right about the timing. I was wondering about a delay between bytes to encourage sync-up, not because the prop can't receive a stream of bytes at 115k (i.e. a delay in lieu of 2 stop bits). But the XBee docs say that it will not output data serially until the input rf stream is idle ... dunno how big its buffer is but it will blast it all out in one go ... therefore a 16 byte buffer may be too small of the rf packet payload is more that 16 bytes , and an inter-byte delay would be of no use. But given your simple test program and the results I would go with Mike's view. Do you have any equipment (a scope?) that could let you look at the serial stream and determine if the clock rates are off? Have you tried slowing down the baud rate to 56700 or 38400 (or even 19200) just to see if it works at a slower speed?
If you need the speed you could try to expand the 16 byte I/O buffers to 32 bytes? Your data packages are 23 bytes long so you might be blowing out the buffer. As I remember, it's a circular buffer and if your not clearing new data out fast enough it can overwrite. I don't see that pattern in your data though.
Jim-
When your problem seems insurmountable, read the forum for a while.
Solve someone else's problems and yours won't seem so bad.
