The demo propellar board comes with a HC-49US 5Hz crystal (or maximum frequency of 80MHz). Can I use a 8Mhz Crystal (or have maximum frequency of 120Mhz)?
The official maximum system clock frequency is 80MHz where it's guaranteed to work over a specific range of temperature and supply voltage. Most Propeller chips will work up to 96MHz and some will work at higher frequencies. There's a graph in the datasheet that shows maximum clock frequency vs. package temperature and supply voltage. You can use an 8MHz crystal, but not with the 16x PLL multiplier.
propeller.wikispaces.com/Oscillator
Look to the bottom of a chart of what has been tried.
OBC
New to the Propeller?
Check out: Protoboard Introduction , Propeller Cookbook 1.4 & Software Index
Got an SD card connected? - PropDOS
