NEW! CO Gas Sensor Module
Jen J.
The new CO Gas Sensor Module is designed to allow a microcontroller to determine when a preset CO gas level has been reached or exceeded. Interfacing with the sensor module is done through a 4-pin SIP header and requires two I/O pins from the host microcontroller. The sensor module is mainly intended to provide a means of comparing carbon monoxide sources and being able to set an alarm limit when the source becomes excessive. Retail price $29.99.
