Newbie Float problems
Hello,
I am having some float problems that are slowly driving me insane so I hope someone can help out or they'll be carting me off in a padded van!
I am making a method for reading in servo pulses using counter registers. I have it all theoretically working. I just can't get it to output to the terminal correctly. This is the code:
·This is an example of the output I get:
The marking of the positive (markPos)·and negative (markNeg)·edge works and the difference between them (pulseRaw)·is·calculated correctly. The·problem occurs·when·I try to calculate·the result in milliseconds (pulseWidth).
If, on a calculator,·I take 132176 and divide it by 80,000 I get 1.65 which is the value I am expecting. i.e. the pulse width·I sent from my servo tester.
If I do the same in spin and then use the floatString object to convert it to a string for the terminal I get 1.401298e-45 no matter what pulseRaw is.
Anybody got any ideas? I'm all out.
Dan
CON
_CLKMODE = XTAL1 + PLL16X
_XINFREQ = 5_000_000
OBJ
fstr: "FloatString" 'Float to String object
debug: "FullDuplexSerialPlus" 'Terminal object
PUB controlLoop | markPos, markNeg, pulseWidth, pulseRaw
outa[noparse][[/noparse]9..10]~~
ctra[noparse][[/noparse]30..26] := %01010 'setup ctra for POSEDGE detect
ctra[noparse][[/noparse]8..0] := 24
frqa~
phsa~
ctrb[noparse][[/noparse]30..26] := %01110 'setup ctrb for NEGEDGE detect
ctrb[noparse][[/noparse]8..0] := 24
frqb~
phsb~
debug.start(31, 30, 0, 57600) 'start terminal for debugging messages
dira[noparse][[/noparse]9..10]~~
waitcnt(clkfreq * 2 + cnt)
repeat
frqa := 1 'Start counters
frqb := 1
repeat until phsa == 1 'Mark time when positive edge is detected
markPos := cnt
repeat until phsb == 1 'Mark time when negative edge is detected
markNeg := cnt
frqa~ 'Reset counters
phsa~
frqb~
phsb~
pulseRaw := ((markPos - markNeg)* -1)
pulseWidth := pulseRaw / 80000 'Calculate pulse width in ms
debug.tx(CLS) 'Send results to terminal
debug.str(string("markPos: "))
debug.dec(markPos)
debug.tx(CR)
debug.str(string("markNeg: "))
debug.dec(markNeg)
debug.tx(CR)
debug.str(string("pulseRaw: "))
debug.dec(pulseRaw)
debug.tx(CR)
debug.str(string("pulseWidth: "))
debug.str(fstr.FloatToString(pulseWidth))
debug.tx(CR)
waitcnt(clkfreq + cnt)
markPos: 1730228749
markNeg: 1730360925
pulseRaw: 132176
pulseWidth: 1.401298e-45
Dan
You are treating pulseWidth as it were a float when it really is an integer.
I hope it solves your issue
That's got it. I was under the wrong impression that the prop stored floats that were calculated from two integers. Now I think about it, it wasn't a very logical assumption. I've implemented FloatMath and it's working fine now.
Thanks again,
Dan
