Prop Current.
The data sheet says:
500uA/MIP does this mean if running on low frequency internal osilator(20kHz) that the draw is only 2.5uA?
Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
· Home of the MultiBladeProps:· SixBladeProp, TriBladeProp
· Emulators (Micros eg Altair, and Terminals eg VT100) - index
· Search the Propeller forums (via Google)
Airspace V - international hangar flying!
www.airspace-v.com/ggadgets for tools & toys
Lastime when I was answering Hippy on your secure module tread I look pretty all electrical caracteristics and graphs but I do not remember this
strange thing is it lists it at 70f si unit is c and have not seen a data sheet use f
I am referring to datasheet V1.1
I had given a look also on page 17 because in 1.1 there is a chapter more (4.8) that takes a page. After that I make a search for the number "500" and only 3 cases exists in the datasheet: two of them are related to crystal and PLL (ohm and kHz) and the last one is related to uA but this is the max forward current through internal protection diodes (here I am explaining to DavidM how to take care on this)
Anyway I think you should refer to chapters 8 (electrical characteristics) and 9 (current consumption characteristics): maybe·it (your data) was an errata if Parallax·has removed from newer datasheet.
·· To help you out, here are older 1.0 and 0.2 versions of the Propeller datasheet I have come across at the Parallax site.
Parallax Propeller Multi-core Controller Data Sheet - Rev 1.1 9/12/2008
http://www.parallax.com/Portals/0/Downloads/docs/prod/prop/PropellerDatasheet-v1.1.pdf
Parallax Propeller Multi-core Controller Data Sheet - Rev 1.0 11/14/2007.
http://www.parallax.com/Portals/0/Downloads/docs/prod/prop/PropellerDatasheet-v1.0.pdf
Parallax Propeller Multi-core Controller Data Sheet - Rev 0.2 4/2/2007 - for historical reference.
http://forums.parallax.com/attachment.php?attachmentid=46365
··· thank you
··· /michael
Datasheet states for 160mips (8cogs@80MHz) a current draw between 3mA and 80/85mA depending on which kind of code is executed (basically how often times the hub is accessed). The manual is good to learn programming. Take the datasheet, it have many more technical informations
Paul Baker
