Cogs and Objects returning situacion — Parallax Forums
HED GROUPHED GROUP Posts: 15
edited 2009-03-07 05:51 in Propeller 1
Hi to everybody can somebody explain us why if we use more than one cog
and call a endless method in the main program the program continue and
cog 2 and 3 blinks led 16 and 23 with led 19 bliking faster.
BUT? if you run the same program using the same method P2 and P3 from a
different object (test1)the first cog (2) run and blink led 16 but the program
stay in that endless method and don't continue with the next instruction.
Is like never return to cog 0 when the cog 2 run it's method from another
object. (Cogs runnig in the same main program have no problem. Cogs runnig
an endless method from another object never return from the first cog - Why ???.
CON
· _clkmode = xtal1+pll16x
· _xinfreq = 5_000_000
VAR
· LONG· cog2ram[noparse][[/noparse]64]
· LONG· cog3ram[noparse][[/noparse]64]
OBJ
· lcd : "TEST1"
PUB Init
COGINIT(2,P2,@COG2ram) ''Blink led 16
COGINIT(3,P3,@COG3ram) ''Blink led 23
DIRa[noparse][[/noparse]19]~~
REPEAT
·!OUTa[noparse][[/noparse]19] ''Blink led 19
·waitcnt(clkfreq / 20 + cnt)
· COPY ALSO THE FOLLOWING METHODS TO "TEST1" FILE
· Remplace the 2 cogs lines with the following:
· COGINIT(2,lcd.P2,@COG2ram)
· COGINIT(3,lcd.P3,@COG3ram)
PUB P2
DIRa[noparse][[/noparse]16]~~
REPEAT
·!OUTa[noparse][[/noparse]16] ''Blink led 16
·waitcnt(clkfreq + cnt)
PUB P3
DIRa[noparse][[/noparse]23]~~
REPEAT
·!OUTa[noparse][[/noparse]23] ''Blink led 23
  • TreeLabTreeLab Posts: 138
    edited 2009-03-07 05:17
    There has been some discussion recently that concluded that you should never pass the address of a spin routine that is in another object to cognew (a relative of coginit. Here is the topic link
    http://forums.parallax.com/forums/default.aspx?f=25&m=331701&g=331706#m331706
    Mike Green's comment is the one to consider carefully.
    Cheers!
    Paul Rowntree
    HED GROUP,
    Here is a way to accomplish what you want to do...
    MainTest.spin
    CON
    OBJ
      lcd : "TEST1"
    VAR
    '  LONG  cog2ram[noparse][[/noparse]64]
    '  LONG  cog3ram[noparse][[/noparse]64]
    PUB Init
    'COGINIT(2,P2,@COG2ram) ''Blink led 16
    'COGINIT(3,P3,@COG3ram) ''Blink led 23
    'COGINIT(2,lcd.P2,@COG2ram)
    'COGINIT(3,lcd.P3,@COG3ram)
    lcd.P2
    lcd.P3
    REPEAT
    PUB P2
    REPEAT
    PUB P3
    REPEAT
    TEST1.spin
    VAR
    PUB P2
        COGINIT(2,P2_,@cog2ram)
    PUB P3
        COGINIT(3,P3_,@cog3ram)
    PUB P2_
        REPEAT
    PUB P3_
        REPEAT
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 3/7/2009 5:57:14 AM GMT
