Propeller protoboard
I recently received a propellor protoboard. i am working on getting things hooked up, but i noticed 3 holes in the top the top one say vin the bottom one says 5v, the middle one is not labeled, is this so that you can hook up a battery pack, if not what is it for
Jonathan
EDIT: Forgot to mention, the power to the board is through the center positive barrel type connector near the power switch. Do NOT connect a battery pack to the holes you mentioned above.
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
Post Edited (Jonathan) : 3/6/2009 9:43:54 PM GMT
