BGMicro has a few 5" LCD Video Monitors — Parallax Forums
Bill DrummondBill Drummond Posts: 54
edited 2009-03-06 22:59 in Propeller 1
They're yuk Pink, but $37.99. They only had 15 at time of this post.
http://www.bgmicro.com/index.asp?PageAction=VIEWPROD&ProdID=12900
[img]http://forums.parallax.com/attachment.php?attachmentid=74008[/img]
780 x 223 - 19K
    edited 2009-03-06 20:48
    I don’t believe the unit is pink…I think the photo is misleading. It looks like an open-frame unit and what you see is the metal frame reflecting and probably messing with the white balance. =) I have a unit that looks just like this that came from eBay.
    Parallax Engineering
  • Bill DrummondBill Drummond Posts: 54
    edited 2009-03-06 22:15
    Chris Savage said...
    I ordered one, Worth $38.00?
  • nicolad76nicolad76 Posts: 164
    edited 2009-03-06 22:40
    do you know what kind of "input"/interface/driver/controller it has?
  • mparkmpark Posts: 1,336
    edited 2009-03-06 22:48
    Says "composite video" right there in the first post.
    It's value·would be determined by you and your needs...the ones I got were $25.00 each and are good for most uses, however the display was a little grainy. I actually found them through a post on these forums. Someone had linked to the seller before when they only had like 4 or 5 left.· I thought the ones I got were worth $25.00 if that helps.· =)
