I am tying to display a real time clock on an LCD screen using the stampworks development kit but I can't figure out how to do it. Does anybody has a suggestion?
One thing that could get you started down the right path is to read the Stamp Works experiment using the DS1307 on the board, including the code. This code displays the time information on the DEBUG screen, however if you look at how this is being done it will be much simpler to get it onto an LCD. As Jonathan points out, you also need to specify what LCD type (parallel/serial) and the manufacturer/model. This will help us to aid you in getting the resources you need. Take care.
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Chris Savage Parallax Engineering
We are going to need a LOT more detail to be able to help.
What LCD are you using?
What is happening?
What have you tried?
What is your code?
How are you powering everything?
And so on. Try to give us as much detail as possible. We can't help you at all with the information you have given so far.
Jonathan
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
