Conditional execution (PASM) woes : RESOLVED (Thanks Phil)
TreeLab
Greetings All;
Some PASM code is driving me crazy, and I just do not get it. Any assistance would be most welcome. Here is the pertinent code ...
I am counting square wave pulses with counter b, and I want to loop within DriveCoil until the phsb exceeds 3. I zero phsb at the start, and in the Update subroutine I send the current value of phsb back to the hub memory, where I examine it with ViewPort.
I can see the phsb increasing exactly as it should at several kHz, but the conditionals never terminate the loop. If I omit the wz,wc effects, I immediately exit the loops.
I am clearly not understanding what is going on here, but it seems pretty obvious. From page 362 of the manual,
CMP Value1, 〈#〉 Value2
CMP (Compare Unsigned) compares the unsigned values of Value1 and Value2. The Z and C
flags, if written, indicate the relative equal, and greater or lesser relationship between the two.
If the WZ effect is specified, the Z flag is set (1) if Value1 equals Value2. If the WC effect is
specified, the C flag is set (1) if Value1 is less than Value2.
The on page 369, the conditionals are described :
IF_BE if below or equal (C | Z = 1) IF_C_OR_Z –and– IF_Z_OR_C
So, can someone explain why my loop never exits?
Cheers!
Paul Rowntree
Post Edited (TreeLab) : 3/6/2009 7:13:41 PM GMT
RunCoil mov phsb, zero mov Time, cnt add Time, pOnCnt DriveCoil mov outa, ActivePin ' turn pin ON mov outa, zero ' turn it off Call #Update cmp phsb, #3 wz, wc IF_BE JMP #DriveCoil DeadCoil cmp phsb, #5 wz, wc ' CORRECTED AS PER PHIL's POST; PROBLEM PERSISTS IF_B JMP #DeadCoil RunCoil_ret RET
Cheers!
Paul Rowntree
Cheers!
Paul Rowntree
The problem is that phsb can't be used as the destination of a read-modify-write (RMF) instruction. Even though you're not modifying it, it's still an RMF (i.e. a SUBtract), but with an automatic nr modifier; and what you're performing the comparison on is phsb's "shadow register". I know it sounds weird, but I'm pretty sure that's what's happening.
Post Edited (Phil Pilgrim (PhiPi)) : 3/6/2009 8:15:50 AM GMT
And now that I know what I am looking for, the Datasheet states :
PHS can only be read through the source operand (same as PAR, CNT, INA, and INB).
If the Tricks and Traps document is still being maintained, this might be a worthy addition.
EDIT : This was the problem.
Cheers, and thanks again!
Paul Rowntree
Post Edited (TreeLab) : 3/6/2009 7:12:57 PM GMT
