Code size — Parallax Forums
Code size
Ken StraussKen Strauss Posts: 10
edited 2009-03-05 15:02 in General Discussion
Some of the new SX/B2.0 features such as STR generate inline code. A few uses of STR will considerably bloat ones code. Is there any way to avoid this behavior other than moving calls to a subroutine? Why doesn't the compiler do this for me?
  • BeanBean Posts: 8,129
    edited 2009-03-04 21:56
    Ken,
    Yes you put them into a subroutine.
    The SX/B compiler is a single pass in-line compiler. It simply translates commands line by line.
    This makes the assembler output easy to understand. SX/B was designed to "teach" assembly by examining the SX/B output.
    Bean.
    There is a fine line between arrogance and confidence. Make sure you don't cross it...
  • JonnyMacJonnyMac Posts: 9,451
    edited 2009-03-05 00:19
    Terry: Could we change STR and HEXSTR so that they expect the address of the array instead of the name -- this would let us wrap them into a generic subroutine
    ' Use: DEC_STR @array, value
    ' -- pass pointer to array and value
    SUB DEC_STR
      STR __PARAM1, __WPARAM23
      ENDSUB
    I can presently get this to work because of what STR expects as the first parameter; or am I missing something?
    edited 2009-03-05 13:06
    Jon,
    If the first parameter is NOT an array, then it is assumed to be the address of the array.
    So you can still but it in a subroutine, but you have to store the parameters because the code for STR overwrites __PARAM1 and __PARAM2 with the "value".
    I could change the code generated so that it doesn't do that...
    Bean.
    Doggonnit -- I actually looked inside the code for STR and should have seen that __PARAM1 was getting overwritten; this works:
    SUB DEC_STR
      aPntr        VAR    __PARAM4
      aPntr = __PARAM1
      STR aPntr, __WPARAM23
      ENDSUB
    Thanks, Terry.
