Is the BS2 HomeWork Board rev. A able to be conveted into the Boe-Bot if I purchase the Robotics with the Boe-Bot Parts and Text, v2.2, or do I have to get the Board of Education carrier board...?
You could make a BoeBot using a HomeWork Board, but the two boards are not quite the same. The HomeWork board has a different layout. There are 220 Ohm resistors in series with all the Stamp I/O pins on the HomeWork Board. There are no connectors prewired to plug in servo motors, etc. On the other hand, you can account for the 220 Ohm resistors. You can put socket pins on the little breadboard to use to connect to the servo plugs and you can add an external power switch so you can run the HomeWork Board and servos off a 6V to 7.5V power source
