Bypassing the voltage regulator??
Purchased a Stamps In Class for a now-canceled project a year or two ago, and have now been asked if it can be used for a middle school control project. Unfortunately, rule-writers have manipulated the rules to eliminate most of the Parallax products-- we can use either 4 AA batteries, or a 4.8v battery pack.
Is there any way we can use 4 AA batteries, a low-dropout regulator to get 5V, and then bypass the on-board regulator on the Stamps In Class board? If so, would it be stable enough to not have fluctuations or spikes from a stepper motor powered from the batteries too? In this case, we have a bunch of tiny steppers and an ultra-light balsa "car"-- a frame only, nothing un-necessary. In fact, it looks nothing like a car other than wheels mounted on the steppers.
Jerry
Jerry
The Stamps in Class board is probably the Board of Education which already has a low drop-out regulator that works fine down to about 5.5V, then quits regulating. The HomeWork board also uses a low drop-out regulator. A 4.8V NiMH or NiCd battery pack won't work for long ... the Stamp resets around 4.3V.
Your best bet is to use 4 x AA Alkaline cells and the existing regulator on the board. Run the stepper motor off the unregulated input voltage (6V). You'll need diodes across the stepper windings to protect against back-EMF and you'll need switching transistors as drivers. Nuts and Volts Column #6 shows how to drive motors using either switching transistors or the ULN2803A Darlington Array. Go to the main Parallax page and click on the Resources tab. You'll see a link to the Nuts and Volts Columns index.
Recharagable batteries usually are 1.25 volts and normally that'd never work for a BS2 on a BOE.
However, freshly charged (And I do me FRESHLY... as in the past hour) NiMH batteries sometimes have a charge of 1.4 to 1.5ish volts. With four of them, this is enough to run the BOE, BS2 and possibly your motors for all of 30 seconds to 5 minutes before the batteries go back to normal charge (the 1.25v).
Do not depend on this though. Test your batteries after charging and run a demo on it. It may not work with your brand.
Another option would be a DC-to-DC boost circuit. Your best bet is to buy one pre-made as the circuit is somewhat complex. You could get 5v off one or two AAs. There might also be one
to use your 4.8v battery pack.
Remember though, a boost circuit drains the batteries a LOT faster than normal. It can also cause overheating problems if you tax the batteries too horribly much.
I believe www.sparkfun.com has a couple boost DC-to-DC converters.
Good luck!
