Crazy Code help
I tried my first attempt at trying to make my bs2 try to learn an rfid tag with the parallax rfid reader. I seem to be having some trouble
My first time really trying to incorporate the WRITE and SERIN commands. I am still trying to fix myself, any hints appreciated.
' {$STAMP BS2}
' {$PBASIC 2.5}
'-------[noparse][[/noparse] I/O Definitions ]-----------------------------------------------------------------------------------------
RX PIN 0
Enable PIN 1
Beep PIN 2
GreenLED PIN 3
YellowLED PIN 4
Starter PIN 5
RedLED PIN 6
DoorWire1 PIN 9
DoorWire2 PIN 10
'------[noparse][[/noparse] Constants ]------------------------------------------------------------------------------------------------
#SELECT $STAMP
#CASE BS2, BS2E, BS2PE
T1200 CON 813
T2400 CON 396
T4800 CON 188
T9600 CON 84
T19K2 CON 32
TMidi CON 12
T38K4 CON 6
#CASE BS2SX, BS2P
T1200 CON 2063
T2400 CON 1021
T4800 CON 500
T9600 CON 240
T19K2 CON 110
TMidi CON 60
T38K4 CON 45
#CASE BS2PX
T1200 CON 3313
T2400 CON 1646
T4800 CON 813
T9600 CON 396
T19K2 CON 188
TMidi CON 108
T38K4 CON 84
#ENDSELECT
SevenBit CON $2000
Inverted CON $4000
Open CON $8000
Baud CON T2400
#SELECT $STAMP
#CASE BS2, BS2E
TmAdj CON $100 ' x 1.0 (time adjust)
FrAdj CON $100 ' x 1.0 (freq adjust)
#CASE BS2SX
TmAdj CON $280 ' x 2.5
FrAdj CON $066 ' x 0.4
#CASE BS2P
TmAdj CON $3C5 ' x 3.77
FrAdj CON $044 ' x 0.265
#CASE BS2PE
FrAdj CON $0AA ' x 0.665
#CASE BS2PX
TmAdj CON $607 ' x 6.03
FrAdj CON $2A ' x 0.166
#ENDSELECT
LastTag CON 1
#DEFINE __No_SPRAM = ($STAMP < BS2P) ' does module have SPRAM?
'-------[noparse][[/noparse] Variables ]-----------------------------------------------------------------------------------------------
#IF __No_SPRAM #THEN
buf VAR Byte(10) ' RFID bytes buffer
#ELSE
chkChar VAR Byte ' character to test
#ENDIF
tagNum VAR Nib ' from EEPROM table
idx VAR Byte ' tag byte index
char VAR Byte ' character from table
Beeps VAR Nib
mysterytag VAR Word
datalog VAR Word
'------[noparse][[/noparse] EEPROM Data ]----------------------------------------------------------------------------------------------
'Tag1 DATA "0F03029F09" ' valid tag
'------[noparse][[/noparse] Select Mode ]------------------------------------------------------------------------------------------------
DO
SELECT mode
CASE = 0
GOTO Reset
CASE = 1
GOSUB Program
ENDSELECT
LOOP
'------[noparse][[/noparse] Initialization ]-------------------------------------------------------------------------------------------
Reset:
HIGH Enable ' turn off RFID reader
LOW DoorWire1 ' sends lock pulse to respective wire
HIGH DoorWire2 ' sends lock pulse to respective wire
PAUSE 2000 ' pulse length is a quarter second
INPUT DoorWire1 ' pulse ends for respective wire
INPUT DoorWire2 ' pulse ends for respective wire
'------[noparse][[/noparse] Program Code ]---------------------------------------------------------------------------------------------
Main:
LOW Enable ' activate the reader
HIGH RedLED
DO
SERIN Rx, 2400, [noparse][[/noparse]mysterytag]
IF mysterytag = datalog THEN
GOTO Tag_Found
ELSE
ENDIF
LOOP
'#IF __No_SPRAM #THEN
' SERIN RX, T2400, [noparse][[/noparse]WAIT($0A), STR buf\10] ' wait for hdr + ID
'#ELSE
' SERIN RX, T2400, [noparse][[/noparse]WAIT($0A), SPSTR 10]
'#ENDIF
'HIGH Enable ' deactivate reader
'Check_List:
'FOR tagNum = 1 TO LastTag ' scan through known tags
'FOR idx = 0 TO 9 ' scan bytes in tag
'READ (tagNum - 1 * 10 + idx), char ' get tag data from table
' #IF __No_SPRAM #THEN
' IF (char <> buf(idx)) THEN Bad_Char ' compare tag to table
' #ELSE
'GET idx, chkChar ' read char from SPRAM
' IF (char <> chkChar) THEN Bad_Char ' compare to table
'#ENDIF
'NEXT
' GOTO Tag_Found ' all bytes match!
'Bad_Char: ' try next tag
' NEXT
'Bad_Tag:
'tagNum = 0
'FOR Beeps = 0 TO 10
' FREQOUT Beep, 250, 4500
' NEXT
' GOTO Main
Tag_Found:
FREQOUT Beep, 500, 4500 ' confirmation beep
HIGH DoorWire1 ' sends unlock pulse for respective wire
LOW DoorWire2 ' sends unlock pulse for respective wire
LOW RedLED ' red LED turns off
HIGH Starter ' starter wire connects
HIGH GreenLED ' green LED turns on
PAUSE 20000 ' program pauses for 20 seconds
LOW GreenLED ' green LED turns off
HIGH YellowLED ' yellow LED turns on signaling 20 seconds have passed
PAUSE 10000 ' program pauses for 10 seconds
LOW YellowLED ' yellow LED turns off
LOW Starter ' starter wire breaks
FOR Beeps = 0 TO 1
FREQOUT Beep, 150, 4500
NEXT
GOTO Main
'----------------[noparse][[/noparse] Programming Mode ]--------------------------------------
Program:
SERIN Rx, 2400, [noparse][[/noparse]datalog]
WRITE 100, datalog
GOTO Reset
Program: SERIN Rx, 2400, [noparse][[/noparse]datalog] WRITE 100, datalog GOTO ResetThen when that variable is written on the BS2, I wanted to make it compare 'datalog' (the written tag) to 'mysterytag' (the tag being presented when entry is desired) by the code that follows
SERIN Rx, 2400, [noparse][[/noparse]mysterytag] DO IF mysterytag = datalog THEN GOTO Tag_Found ELSE ENDIF LOOPPerhaps part of the source I commented out had something important to it that I did not take into account?
