Basic Stamp - Car Battery
I plan to build a project that will run in the car. I will therefore try to use the cigarette lighter to power the stamp through a 5v regulator and a couple bypass caps. Is there anything special I need to know about this setup (e.g., are automobile batteries subject to many transients; do I need any special setup)? Any help or advice would be appreciated.
I am an electronics moron. However, take a look at the end of this thread on the SX forum. The DC-DC converter I built emulates the Professional Development Board power regulation circuitry. I run it off two 12 volt, 12 amp hour batteries in parallel·for a total of 12 volts and 24 amp hours. I imagine it would work just as well on a car battery. If there is a lot of noise in the circuit you wish to power, perhaps something else or a change in capacitance (I dunno; I'm a dummy) might be appropriate.
--Bill
You are what you write.
