7-bit serial mod for fullduplexserial? — Parallax Forums
luftphotoluftphoto Posts: 5
edited 2009-03-04 02:30 in Propeller 1
I'm drawing a blank on this one. I assume the assembly portion of the "fullduplexserial" code needs to be changed to force it to use 7-bit word length instead of 8. I know the BS2 library will support it, but I'd rather stick with fullduplexserial if possible.
Any ideas?
  • KyeKye Posts: 2,200
    edited 2009-03-04 00:42
    Make sure that the last bit of every piece of data you send is one.
    That will basically act like a stop bit allowing 7 bit data transfers.
    Nyamekye,
  • AribaAriba Posts: 2,697
    edited 2009-03-04 02:07
    Here is a FullDuplexSerial variation, with adjustabel Databit size, Rxbuffer size and Parity on transmit.
    This is not extensive tested!
    Andy
  • luftphotoluftphoto Posts: 5
    Thanks Kye, and thanks Ariba for the code - I'll try both.
