Thanks for the great article. When will the MyDanceBot be available? Yes, I'm on the waiting list. I have built a couple of AVR Butterfly based Balance Bots and I can say that it's not as easy as it looks. Currently I have a BoeBot sporting a Prop Proto Board, ping sensor mounted on a servo. I just added a serial bluetooth connection (Blue Smurf) and I'm looking forward to adding viewport and seeing what that's all about. After viewport, my plan was to re-purpose my IMUs and the like and build Prop based Balance Bot, but now I'm thinking about doing the vision thing first.
Be careful using the "next" at the bottom of the page..
it tends to jump you to the next article. [noparse]:)[/noparse]
I was starting to think Hanno was onto a new watering project for a moment.. [noparse]:)[/noparse]
OBC
New to the Propeller?
Check out: Protoboard Introduction , Propeller Cookbook 1.4 & Software Index
Got an SD card connected? - PropDOS
So many projects...
James Ronald
JMH
