Has the SXsim nevest version?
I use the SXSim 2.08.06 version. Simulating SX28 it is okay, but when I used it for SX48 the I/O panel not shows right the pins I/O state. Their state matches with the TRIS register, but not matches with the runing program settings. I use simulator from SXB. Can be this the problem?
Regards
Spiller
Regards
Spiller
Can you post a short program that shows the problem ? And maybe a screen shot of the simulator ?
Bean.
There is a fine line between arrogance and confidence. Make sure you don't cross it...
http://forums.parallax.com/showthread.php?p=784813
regards peter
I read the discussion which can be found under the link you have sent me. I understood the problem, but what to do?
Should I check and edit the list file all the time when I like to run the simulator?
Regards
Spiller
For now. I think you must live·with·it.
regards peter
