source for strain gauge
I am trying to find a source for a strain gauge for a project I am working on.
something similar to this:
It will be used when a certain amount of force is being applied to the shift lever on my race bike to initiate an ignition kill/nitrous cutoff.
Devin
Devin
- Stephen
Maybe I will have to build one from a flexiforce sensor.
Devin
- Stephen
Thank you,
Devin
As I understand your query you are not looking for actual strain gages. If indeed you are however, you might consider the following source:
http://www.vishay.com/strain-gages/
Their MicroMeasurements division is the 'Parallax' of strain gages; in that, they offer an excellent product, fortified with a wealth of educational material:
http://www.vishay.com/strain-gages/knowledge-base-list/
If I can be of further help with regard to using strain gages as the basis for your sensor please ask. MicroMeasurements gages can often be found on e-bay and there are application tutorials offered online.
cheers, David
I am going to try the flexiforce sensor with my design and see if this works.
Devin
Understand that the flexiforce senses compressive force; and not strain. [noparse][[/noparse]I can think of a mechanical arrangement wherein you could use it to sense tensile force.] In either case I believe it needs to be calibrated.
Some time ago, at a Stamp user's request, I received a sample flexiforce sensor and made a simple arrangement to apply a known compressive force in order to calibrate it. As I remember the sensor had a unfathomable trait which made it not as accurate as I would have liked. But experiment yourself - you may find that it is fine for your use.
As I mentioned previously, if you find that you would like to try using the standard strain gages let me know if I can be of help.
cheers, David
