stored data transfer or to export — Parallax Forums
oopoop Posts: 28
edited 2009-05-18 15:31 in General Discussion
Please guide about how to transfer stored data (visualised in stamp editor through pc monitor) to other system or to plot in excel or to mix other data .
  • Erik FriesenErik Friesen Posts: 1,071
    edited 2009-03-02 14:25
    Can you explain what you are trying to do?
  • oopoop Posts: 28
    edited 2009-03-11 12:14
    sir,
    can be stored in PC whichever the data are stored in eeProm of basic stamp ?
  • sylvie369sylvie369 Posts: 1,622
    edited 2009-03-11 12:33
    If I understand your question, this will probably be helpful:
    http://www.parallax.com/ProductInfo/Microcontrollers/PLXDAQDataAcquisitiontool/tabid/393/Default.aspx
    It's code that enables you to read data from a Basic Stamp into MS Excel.
    A more basic answer would be to simply use SEROUT to send data from the Stamp to a COM port on your PC, which you monitor using a terminal program (Winterm, Realterm, etc.). Those programs generally have a "capture to file" function that will allow you to save the incoming data to a file.
  • oopoop Posts: 28
    edited 2009-03-18 06:15
    sir,
    in the project the data are stored in bs2p eeProm and can retrive also.but how to read stored things of eeProm/bs2p in MS EXCEL and in graph in this report? Add sample program on winterm/hyperterm from BS to com port of PC.
  • dandreaedandreae Posts: 1,375
    The Stamp Plot Pro will work for you regarding·graphing.· Here is a link for the download:· http://www.parallax.com/tabid/441/Default.aspx.·
    Dave
    Dave Andreae
    Parallax Tech Support·
