Alternative, Portable and Renewable Energy Source for the BOE-BOT
I'm planning to get my BOE-BOT to have an environmentally friendly energy solution instead of using disposal Batteries.
Any Ideas?
Solar Panels won't work well at night anyway.
And the Honda Hybrid engines are just too big, bulky, expensive and the fuel is non renewable.
Any Ideas? Again?
I would take Hydrogen Fuel cells as an answer if there is any...
Or even the energy source I mentioned in my signature...
BWIN ON DA POWAH WIFIN U!!!
(This means the Plutonium Isotope Nuclear Fission And Fusion Reactor Battery Pack you've been hiding inside your jacket!!!)
Any Ideas?
Any Ideas? Again?
Umm... those may be renewable but... I wouldn't count them as renewable though because over a certain period of time, the battery life "degrades".
Meaning that after many years, they won't work at all.
I'd say they at partially renewable.
After they stop working, the chemicals inside are filling up our dumps.
Why? Because...
"Boy Scouts! This ain't!"
"A stroll in the Park?! This ain't!"
"Happy Camping?!?! This ain't!"
"A Hobby Robotics revolution?!?!?!?! This ain't!!!"
"Am I going off topic?!?!?! This sure is!!!"
If you're asking for a practical source of "renewable" power in an area where there's plenty of sunlight during the day, then high quality NiMH rechargables and a solar cell array with careful power management is the best way to get power for years. You will get slow degradation of both, but you design for it along with enough excess capacity.
- Stephen
One question kwinn, Where do I get that?
And how much is it? That would be a splendid PSU if it were cheap!
The Idea of a combination solar panel with rechargable batteries is a great idea!
Thanks guys.
(Note, the plutonium power cell isn't worth it. I may die from radiation poisoning...)
NiMH batteries? Okey! I'll take that into it.
Now how do I incorporate a self charging mechanism when the robot is not in use...?
Hm... Oh well, Back to the drawing board. (Microsoft Paint)
Post Edited (Ezsynn) : 3/3/2009 9:16:11 AM GMT
Any Ideas where to get them in Australia?
I just googled model RC car australia. lots more links, too.
A standard alkaline AA battery puts off 1.5 V but a rechargeable NiCad or NiMH has a lower voltage (1.2). So if you use the standard battery pack of 4 AA batteries and use rechargeable, you may be trying to run your 5 V Basic Stamp with only 4 x 1.2 = 4.8 Volts.
Parallax has a solution Boe-Boost Module Item code 30078. I've just ordered one. Looks like a slick way of adding a 5th battery in.
a few ideas that I'm mulling over for a similar project. You've mentioned solar, but most likely you'd want to use the solar to charge the battery. So you've still got some sort of rechargeable battery in the loop. You could use Solar to split water to hydrogen and oxygen and use that for a fuel cell.
Kind of low tech, but I use enough things that have rechargeable batteries and I also do a lot of bicycling. When not cycling, I come home at night and ride a stationary bike (well road bike on a supported stand with magnetic resistance). Why not use the effort I'm putting into the bicycle to run a generator to charge a 12V battery . Then use the 12V battery to replace a few wall warts as well as recharge my rechargeables ?
How does that work?
Thanks Mike! Even though sometimes I find you a tad serious.
You're the guy who never lets me down on Ideas.
Wind the bands to store the energy that will drive the generator
which will create the power to run the robot. Use a clutch to control the
energy release.
A series of bands will store up the energy and can be staggered
in their operation to release energy, like a tag team handing off the
baton of energy.
It's like getting a toy airplane to fly using a plastic prop and that big
elastic band - I'm sure we've all see those...
Albeit it stores a limited time of energy, but it may create an interesting
science project and it's totally green! Wow the neighbors with your new
Elastic Energy Propelled Robot!
How you turn the bands to store up the power is the green part.
You can use good old fashioned "elbow grease" or wind power, or a
miniature water fall. You could collect rain water in a barrel and release
it.
Have an exercise bike, or put a storage unit on a regular bike. Your
exercise will pay off in power dividends! Too lazy? Perhaps your pet
hamster likes to go around and around in his wheel. Harness it!
If you live by the ocean, waves can also impart energy to be stored in
the system. All this stuff works at night to meet your requirements.
A day option is to use a steam engine. A large magnifying glass will
heat the water to turn the turbine engine.
And as a closing note - use vinegar and baking soda. You can find both
substances in your kitchen! The mixture will build up great pressure with
considerable power, even enough to launch model rockets. Check the
web, you can even go with a stack of Mentos and Coke soda pop.
humanoido
Wind Power which gives off 10V DC.
Anyone know how to change it to 6V?
Anyone know of an ohm to Voltage converter? (As in telling me 1 volt equals to how many ohms?)
V=IR
You need to learn some basics about electricity, including the meaning of voltage, current, resistance, Ohm's Law, and the power law (Power = voltage x current). A good place to find explanations is the Wikipedia. Try doing a web search for "Wiki Ohms Law" for a start.
Not knowing this really really fundamental stuff is like peppering your speech with "ain't" and other slang. I don't care how smart you might be, it makes you sound ignorant.
Okay, so I need to do some homework?
I can handle that.
Good Luck Ezsynn with your venture,
Jax
If a robot has a screw then it must be romoved and hacked into..
PG
Pi Guy,
Which motor did you use? The main turning motor or the eject motor?
Jax
PG
Jax
Basics behind electricity and electronics:
http://www.reprise.com/host/electricity/default.asp
Electronic components, what they are and how they are used:
http://www.kpsec.freeuk.com/compon.htm
Basic electronic theories (including how to read schematics):
http://ourworld.compuserve.com/homepages/g_knott/index1.htm
Basic electronic circuits:
http://www.seattlerobotics.org/encoder/mar97/basics.html
Various electronic tutorials (including decent beginner info):
http://www.hobbyprojects.com/tutorial.html
There are plenty more out there if you look.
Good luck!
