measuring rpm off a tesla turbine
i need to measure the rpm of a tesla turbine, one problem, i cant touch the shaft. one idea i had was to shine a laser at the exhaust holes and then when there was no hole it would act like a mirror and bounce the laser back at a sensor, so that the angle of reflection would be different if there was a hole compared to no hole. my question is would a light to frequency converter work better than a photoresistor, i plan on using a propellor chip that way i have the speed to read the sensor, any comments or suggestion will be very appreciated
I've thought about building one for grins, did you get the disks CNC cut?
Thanks for any info,
Alex
If at first you don't succeed, then skydiving is not for you.
will post pictures when done working on scholarships, currently i am using compressed air to power it, i am working on a nozzle to direct air into all disk spaces, its about 2" in diameter there·are 4·holes· 1/4" in diameter i have built about 5 turbines, the first time i ever built one i made it out of cd cases and had a styrofoam housing, no bearings and paper spacers, i got it spinning so fast it melted the cd case faceplate and when the blades hit the houseing the paper spacers exploded and it was in shambles, the next one was the same but with bushings, i exploaded without touching the housing wall, the next few were made from sheet metal cut with a hole saw, they worked good,i have use fender washers, but·you need to get a bunch of them because there is no precision to the thickness,·3" disks seem to run awesome with 100-120 psi, 2" disks are good at lower air speeds with a smaller nozzle, the one im working with right now i machined from 2.5" aluminum and used a cut off tool to cut the disks, the spacing is a little to big, but when i get parts fro my lathe i plan on making an even better one
PS - Don't forget if you have 4 exhaust holes in the shaft you will get 4 pulses per revolution.
In general, if the number of pulses per second, say, is greater than the square root of the·number of counts per second you can count, then you count pulses; otherwise you count the time between pulses.
Example: Say the shaft is turning 100 rps, and you can count in microseconds. Then if you count shaft rotations for a second, you'll count 100, getting a resolution of 0.01 second (which is 1% of the measurement). But if you count microseconds from pulse to pulse, your measurement will be 10,000 microseconds, with a resolution of 0.0001 second, or 0.01% of the measurement. You would probably choose to count the time between pulses.
But if the shaft is turning 10,000 rps, which is pretty fast, then you'd only count 100 microseconds per pulse, getting 1% accuracy. Counting the pulses for one second would give you 10,000 pulses, with 0.01% resolution.
So you should figure it both ways: How accurately can you measure time, and how accurately can you (instead) count pulses?
· -- Carl, nn5i@arrl.net
Post Edited (Carl Hayes) : 3/3/2009 1:52:06 AM GMT
