You can use the [noparse][[/noparse]Timeout, Tlabel] variables·in the SERIN command list to wait for a specified period of time and move on but the timeout feature is not selective and it will trigger on any serial data that is received. You will need to add some code for error trapping if you use these features.
· The label is a name you give to an address in your program.·· If you want the program to continue without any error-trapping routine then just add a label (a name followed by a colon) on the next line of your program.· The label works just like the one you would add to a GOTO or GOSUB statement.·
Craig Eid
www.TriadRD.com
