vb and prop question using eb500 — Parallax Forums
russ christensenruss christensen Posts: 84
edited 2009-03-01 00:44 in Propeller 1
Hi everybody, yet again. Since today is the day I'm devoting solely to working on my robot, i have another question. I'm having issues passing data from the prop to my vb program. Just testing i'm sending a string through the bluetooth every 100 milliseconds. the first one shows up in my text box immediately, a moment later about 15 more show up, then i don't get anymore for a while. however they do keep coming. I need the data to show up right when i get it, does anybody know how to print the buffer immediately?
  • UnsoundcodeUnsoundcode Posts: 1,532
    edited 2009-02-28 23:35
    Hi Russ, it depends on your version of Visual Basic. I know that if you are using Visual Studio·2005/2008 you would capture data coming to the PC with the Data Received event handler and then pass it on to the text box using a delegate.
    Jeff T.
  • russ christensenruss christensen Posts: 84
    edited 2009-02-28 23:41
    Thats exactly what i'm doing, but there's still a delay. Here's some code if anybody cares to take a gander. it is using vb2008 and steve norris's eb500.spin which is also attached
    edit: most of the code i adapted from this tutorial.
    http://www.devx.com/dotnet/Article/31001/0/page/2
    Post Edited (russ christensen) : 2/28/2009 11:53:15 PM GMT
    edited 2009-03-01 00:29
    Hi, DevX is a good resource. I don't have the time right now to look at your source perhaps someone else can help with that. I did have time to jot an example down onto Notepad , insert it into your existing code and see if it makes any difference.
    Note it uses a RichTextBox not a TextBox , alter that if you need to.
    Jeff T.
    EDIT: error, switch the two lines that receive byte values or ASCII I labelled them wrongly.
    Post Edited (Unsoundcode) : 3/1/2009 12:38:45 AM GMT
    edited 2009-03-01 00:41
    omg unsoundcode i love you. your code worked great. not sure what was wrong with my code, thank you very much!
    One more question. since the send line and receive line are different, can i have one cog listening and one cog sending at the same time, without conflict?
