wireless usb
Hi guys, a couple days ago i posted in the forum about possible new parallax ideas about wanting a way to program my prop wirelessly. Now i'm wondering if anybody has heard of a wireless adapter for usb, in which there is a usb port that will plug into my prop board, and either the same on the other side, or bluetooth. Anybody ever seen anything like this? if it just uses a virtual serial port, i don't see why it wouldn't work.
Russ
Russ
It is almost two years later after the initial post, and I was wondering if this timing problem issue Mike talks about has been solved. I was thinking about going out and getting a wireless D-Link usb hub for my PC. Sitting on the couch with the laptop is ok for programming, but what I want to do is set up the hardware, propeller demo board, a VGA and a propscope on the table about 10 feet from the couch while I relax and write some test code. Getting up to move a probe is ok, or to change the circuits, but having the be hardwired to all this is something I would like to solve for development purposes. I am pretty sure it will work with many different types of USB devices but am specificaly interested in if anyone know if this will work with the following two devices. 1. A USB propeller demo board, and 2. A propscope.
ftp://ftp10.dlink.com/pdfs/products/DUB-2240/DUB-2240_ds.pdf
If this wireless USB device will not work, can someone suggest one that will.
Thank You,
Walt,
