UART to PC
Does anyone have experience using a PC to talk to a one-wire UART on a microcontroller? We are trying to use LabView, but may be able to use C or C++ if possible. We’re also playing around with trying to create a circuit that will turn the two-wire serial communication to a one wire UART. Any ideas? We're trying to get our robot's motor controllers working with the computer. Thanks!
1 Match the voltage levels
2 Connect ground and serial data line
3 Jumper the handshake signals or disable handshaking in software
Richard
[FONT=Arial,Bold][FONT=Arial,Bold]"PlayStation Control Redux"...I also found the C#2005 code with BS2 code that MSRS.1.5 used for communication "on the side" if you want to play with that.....I hope this get you started in the right direction.
[/FONT][/FONT]
