Near Field Magnetic Induction Charging
I want to charge lithium-ion batteries using magnetic coupling. This occurs in cordless toothbrushes that rest on a waterproof charging base.
I want to charge a 3.6 volt lithium polymer cell. I know all about the physics of inductive coupling and transformers.
What do you recommend for coil in the fixed base and portable unit? I need recommendations on frequency, inductance, coil turns and such.
I want magnetic coupling for safety reasons and easy-of-use. I've got plenty of circuits to charge lithium polymer batteries.
But the magnetics I'm not so sure of. Damn the inverse square law!
JMH
JMH
As for frequency it depends on the coil size but uully higher frequencies are better. 200kHz is probably a good starting point.
Need to make your prop design easier or secure? Get a PropMod $50CAN has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module.
I'll wind the coil on a plastic sewing-machine bobbin, then try different caps to zero in on the resonant tank freq.
Light weight is also a freebie, since the bobbin is air core. If need be, I can insert a ferrite slug if things don't work out.
Maybe a Colpitts oscillator or just a 555 driving a power FET or 3055 junction transistor will do.
JMH
Post Edited (James Michael Huselton) : 2/28/2009 3:16:34 AM GMT
· -- Carl, nn5i@arrl.net
JMH
It saves us from, well just about everything. Noise, heat, light, xrays, alpha, beta, gama, mother-in-laws....[noparse]:)[/noparse]
Stars would collapse around a mile across and would last one year. Sound would propogate very weirdly.
JMH
Post Edited (James Michael Huselton) : 2/28/2009 4:29:48 AM GMT
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
(I'm in my first of 3 Electromagnetics classes at my University)
·"I have always wished that my computer would be as easy to use as my telephone.· My wish has come true.· I no longer know how to use my telephone."
- Bjarne Stroustrup
JMH
