??? The PPDB comes with a L293D chip ???
I'm confused, I started learing on the Bs2 Development board
and am just getting started with the prop (got the PE kit and a proto board)
I want the prop to drive a stepper motor and see the PPDB cames with the same push pull driver chip ( L293D )
but the data sheet has a min. voltage over·4 volts for logic?
won't it function poorly at 3.3 or is there some trick to using it?
I would like to know .·· Thank You.
Cheers!
Paul Rowntree
Not sure if you are going to drive stepper on the PE Kit or PPDB but both boards come with a 5 Volt and 3.3 Regulator. On the PPDB Vdd to the L293D is supplied with 5VDC and Pin 8 (Vmtr) can be connected to Vin or an external supply. I use the standard power to drive the standardard Parallax stepper motor.
Hope that helps.
Jim
I was planing on buying a new chip (L293D) and using on the propeller Proto board or making a PCB for it.
Is there a better chip to get instead?
Did I mention same pinout. Drop in replacement.
···· thanks
