Switch-mode voltage regulators
What do you guys use for switch-mode voltage regulators? All I can find are these:
http://www.dimensionengineering.com/DE-SW033.htm
Do they work? I imagine that making your own wouldn't bee too difficult. It says that with an additional capacitor on the output it is possible to run ripple-sensitive ICs.
Investigate: Texas Inst. PT5100 series and Datel 78SR series
Cheers,
Tom Sisk
http://www.siskconsult.com
Thanks for the ideas.
Mike2545
This message sent to you on 100% recycled electrons.
Anyway, the 78SRs are great devices, keep 'em under 1/2A and you're golden, old chap.
And they cost about 1/3 less than the PT5100s.
Yea, plain Jane 7805 voltage regulator, you know, 5 bucks a gross.
Anyway, other than almost no heat produced what other advantages does a switching power supply/regulator have over a traditional one?
Mike2545
One of the draw backs, is that a switcher does add a little noise to the supply, but this can almost always be negated by adequate bypassing capacitors. Usually isn't a problem except for extremely sensitve devices.
I usually use the pre-assembled reg. boards linked to below --- 2A continuous, and they have the same pinout as 7805, 2940, etc, and about the same footprint as a 7805 with a heatsink. Assembled, tested, ready-to-go. (I know some may think these pricey, but sometimes it's nice to just have the unit ready to drop in).
search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=PT78HT205V-ND
