schematic software
Hi guys, some of you have some pretty neat looking schematics for your projects, i'm wondering what kind of software your using (if any), and how easy it is to use. I'm not an electrical engineer by any means, i just want to be able to post something that other people would understand when i'm finished with the project i'm working on.
Russ
Russ
http://www.expresspcb.com/
Jim-
Signature space for rent, only $1.
Send cash and signature to CannibalRobotics.
Russ
Need to make your prop design easier or secure? Get a PropMod $50CAN has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module.
Airspace V - international hangar flying!
www.airspace-v.com/ggadgets for tools & toys
Its a great program and now you can use the freerouting.net java
router. It's slower than Eagle, but the routing algorithm does not
quit until it's done.
Scott
Easy to use, complete, good tutorial and free for up to 250 pins.
It also generates standard Gerber files, useable by any fab house.
I like it so much I've upgraded to the 2000 pin version.
The free version of eagle only has these restrictions:
* The useable board area is limited to 100 x 80 mm (4 x 3.2 inches).
* Only two signal layers can be used (Top and Bottom).
* The schematic editor can only create one sheet.
I have upgraded to the full version but the free will do most hobies if you keep things close.
The user interface of Eagle feels a bit cumbersome to me. I think Eagle has been in development since the 90's, and while that testifies to the staying power of·the application, it can also lead to some weird feature and user·interface evolution.
Edit: As a comparison between pin count and board size, my most recent 100mm x 80mm Eagle project has 424 "drills" (same as diptrace "pins"?). The board is a fairly tightly packed through-hole design.·Thus if I transitioned to diptrace, I'd probably go with the 1000 pin non-profit license. Eagle also offers a non-profit license, at 160x100mm board size. Both are priced at $125.
Post Edited (smbaker) : 2/28/2009 5:57:02 PM GMT
Searider
Massimo
Russ
