MC14489BPE LED driver with SX
I am very new to the SX chip and somewhat new to microcontrollers in general so bare with me.· I am trying to make a digital display to output voltage, current and capacity of a battery pack.· I am using 2 MC14489BPE LED drivers to drive 9 7 seg LEDs for the display.· I am trying to get the first one to work, and I am getting sporatic results.· Sometimes I will run my code and it will work, then I will hit reset and the display blanks.· More often I will run the same code and nothing is displayed, then after disconnecting and reconnecting the power the display will appear.· If that is repeated the display returns to blank. Any ideas why I this is happening?
' Program Description
'Making a digital display with 3 groups of 3 digits of 7 segment LEDs
' Device Settings
DEVICE········· SX28, OSC4MHZ, TURBO, STACKX, OPTIONX
FREQ··········· 4_000_000
' IO Pins
Din···PIN·RA.0 output
CLK···PIN·RA.1 output
Enable·PIN·RA.2 output
· PROGRAM Start
Pgm_ID:
· DATA· "SX/B Template", 0
' Program Code
Start:
·HIGH Enable·
·LOW· CLK
Main:
··LOW Enable
··SHIFTOUT Din,CLK, MSBFIRST,%10001110
··SHIFTOUT Din,CLK,·MSBFIRST,$00001001
··SHIFTOUT Din,CLK, MSBFIRST,%00001001
··HIGH Enable
· GOTO Main
http://www.datasheet123.com/291272/MC14489BPE.html
It's not letting me upload the datasheet so here is a link.· I am using an Rx value of 1Kohm.·Thanks for the help.
' Device Settings
' IO Pins
· PROGRAM Start
Pgm_ID:
' Program Code
Start:
·HIGH Enable·
·LOW· CLK
Main:
··LOW Enable
··HIGH Enable
· GOTO Main
Try this:
Bean.
There is a fine line between arrogance and confidence. Make sure you don't cross it...
Post Edited (Bean (Hitt Consulting)) : 2/27/2009 3:48:03 PM GMT
