Propeller working with the BS2
Hello everyone,
I am new here in the forums. However, I have been a Parallax customer for some time now. I hope that these forums live up to the Parallax reputation.
I am performing a little experiment. I have been using BASIC Stamps for a while and consider myself somewhat proficient in there implementation. I am now playing with the Propeller chip and trying to use it in one of my projects. What I would like to know is whether anyone has used the propeller and the BS2 in the same project having them communicate with each other. I would like to know how it was done and if it worked?
Thank you for your responses
Calaway21
Calaway21
From a hardware standpoint, you just need to put a 4.7K or 10K resistor in each I/O lead between the Stamp and the Propeller, just like you'd do if you connected one Stamp to another ... to protect the chips from accidents where each chip sets their I/O pin to output state, but of opposite polarities (one HIGH, one LOW). This shouldn't happen, but mistakes get made and you don't want them to blow out a chip or I/O pin.
I've been thinking about this for a while. Now Hanno has OpenCV in Viewport, I figured you could use a BS2 to control 2 servos with little cocktail flags attached to the horns, and have the propeller look at the images using a camera and the OpenCV plugin. You could then have them talk to each other using Semaphore!
How about a LED and PhotoTransistor using Morse Code? (Automated Aldis Lamp!)
But seriously, the easiest way to do it is using standard Serial output/Input from the BS2 (is it SERIN/SEROUT?) and FullDuplexSerial or SimpleSerial on the propeller. You will have to use a resistor between the TX of the BS2 and RX of the propeller to protect the pin (as the BS2 is a 5V device and the Propeller is 3.3v) but that would be the easy way to do it.
Cardinal Fang! Fetch the comfy chair.
Hanno
... using only items commonly found at the dentist!
"They may have computers, and other weapons of mass destruction." - Janet Reno
Calaway21
